colinsunderland
- x 3
Re: Citroen and Peugeot Parts Requests
Hi Marc
Any chance of a part number for the rear left abs sensor
Had it in a garage this afternoon who said the back of the discs rust up quite often and cause the sensor to knock against it so I might have to change the pads and discs too, is that right or is he trying to scam me lol
Are the sensors easy to change does anyone know?
I know the brake switch goes commonly on these, as the auto handbrake isn't working either, and they cause all sorts of errors, it wouldn't be that would it? Diagbox isn't giving a handbrake error but it shows on the dash
Thanks again
Thanks again
- x 6948
No indication of this - it is the original part number with the following dimensions: DIAM 157,75X30 EP 30.Huskyxantia wrote: 29 Dec 2021, 09:43I take it item 12 is the modified pulley ?GiveMeABreak wrote: 29 Dec 2021, 02:55 Item (12) Part: 0515T3 £161.40
I'll have to try and get the other info later
- x 6948
If its (16) - Elastic Collar, then part: 1434G7Huskyxantia wrote: 29 Dec 2021, 14:23 Needing part number for the spring clamp that holds the pipe onto the turbo intake side. For my 206cc 1.6hdi
Thanks marc.
- x 6948
Yes, as far as Christmas this year goes - locked away and stuffing!Rhothgar wrote: 29 Dec 2021, 12:10Sorry to pester Marc. Any chance of confirming this pretty please?Rhothgar wrote: 26 Dec 2021, 17:02 Whilst I think about it, is 1854.24 the part number for the engine rear lower mount which straps the engine mount (which the intermediate driveshaft goes through) back to the subframe please?That's an embarrassed face by the way. Hope you had a good Xmas.
These are the engine mountings - no part with number listed. Let me know which item you need from the diagram.
- x 6948
Couldn't tell you Colin - I've never had one fail ever, but certainly knocks and weathering can cause issues.colinsunderland wrote: 29 Dec 2021, 15:10 Hi Marc
Thanks again
Rear ABS Sensor, item (2), Part 4545K8, £74.99
KennyW
- x 165
Parts Diagram Please
Please can the parts diagram be posted for the Underbody protection for my C5 x7
VRN : VF7**************[VIN obfuscated, can be read by forum staff]
Kenny
Kenny
Reason: Moved to Parts Requests Forum
C3 1.4 petrol (SWMBO)
- x 6948
Here Kenny:
I have indicated the main parts you have. If you need part numbers, let me know the item numbers.
Rhothgar
- (Donor 2026)
- x 222
I’ll have a 10 please, Bob!GiveMeABreak wrote: 29 Dec 2021, 20:10
If cross referencing is available great. If not, no problem 1854.24 I hope.
Huskyxantia
- x 927
4 number 72's , i checked my routing of these pipes today and they were on the other way, so i changed them, things is my engine light came on this evening while driving so tomo im putting them back how they were .GiveMeABreak wrote: 23 Dec 2021, 16:40 Here you go:
If it's the gas temperature pipe / sensor that is item (1), part 1618LS, £135.44
Item (4) is the actual DPF Differential Pressure Sensor and that part may no longer be available (1618LP), so they recommend using part 1618Z9, £96.59
Pipes:
(7) is the pipe upstream of the sensor 1618P2 (no longer available)
(9) is the pipe upstream pf the particle filter 1618P4, £19.91
(8) is the pipe downstream of the sensor 1618P3 (no longer available)
(10) is the pipe downstream of the particle filter 1618P5 (no longer available)
Reason: fixed quote code
Husky.
- x 6948
@ Husky:
Item (72) Part: 6981P4, 67p each. Be aware, I've known PSA to sell minimum order quantities of these types of clips - I ordered another type some years back for the boot fizings and ended up having to buy a bag of 25!
Huskyxantia
- x 927
Ive been had that way many moons agoGiveMeABreak wrote: 29 Dec 2021, 21:39 @ Husky:
Husky.
Huskyxantia
- x 927
Hello marc
Have you part number for Turbo air pipe sleeve for 206cc 1.6hdi, why do mine split so easy ?
Husky.
- x 6948
Turbo Air Piping: Let me know item.Huskyxantia wrote: 30 Dec 2021, 11:35 Hello marc
If Air Hose from Air Intake, advise of item number from Diagram from other post here:
viewtopic.php?p=705811#p705811
Huskyxantia
- x 927
Other side of the turbo its the orange rubber piece, air in take seal ? I thinkGiveMeABreak wrote: 30 Dec 2021, 11:42Turbo Air Piping: Let me know item.Huskyxantia wrote: 30 Dec 2021, 11:35 Hello marc
Husky.
Huskyxantia
- x 927
Number 14 is the part ive had 2 go within a few monthsGiveMeABreak wrote: 29 Dec 2021, 20:06Huskyxantia wrote: 29 Dec 2021, 14:23 Needing part number for the spring clamp that holds the pipe onto the turbo intake side. For my 206cc 1.6hdi
Thanks marc.
Husky.
