206 Radiator
admiral51
(Donor 2026)
x 391
Re: 206 Radiator
Unread post by admiral51 »
Husky i don't see any issue with leaving the A/C rad out providing the pipes are tied up and out of the way.
The only issue i see is if you need to use the A/C to demist the car in the winter, unless of course you have a Sheepskin Coat/Gloves and a DeerStalker hat that will enable you to have the roof down in the winter :)
Colin
Huskyxantia
x 909
Re: 206 Radiator
Unread post by Huskyxantia »
admiral51 wrote: 22 Dec 2021, 16:56 Husky i don't see any issue with leaving the A/C rad out providing the pipes are tied up and out of the way.
Colin
You've seen me driving around then .... :)
:-D
Huskyxantia
x 909
Re: 206 Radiator
Cars all up and running my brain storm worked air con pipe wedge right out of the way of everything.
:-D
x 6945
Re: 206 Radiator
I take it that’s a joke right..... :?:
Huskyxantia
x 909
Re: 206 Radiator
Me in a Deerstalker ?
:-D
x 8123
Re: 206 Radiator
He's thinking of me!! :-D :-D
Huskyxantia
x 909
Re: 206 Radiator
:rofl2:
:-D
Huskyxantia
x 909
Re: 206 Radiator
\:D/ \:D/ \:D/ :snowman: :snowman: Merry christmas everyone !
:-D
Huskyxantia
x 909
Re: 206 Radiator
New dpf and sensor but the unblock diesel filter comes up at every startup this is the last niggle that needs fixing
I have a new fuel filter too only done about 900 miles.
Any suggestions , ?
:-D
Huskyxantia
x 909
Re: 206 Radiator
Huskyxantia wrote: 22 Dec 2021, 12:22
Huskyxantia wrote: 22 Dec 2021, 10:22 My replacement rad is due this morning ! I'm watching the tracking live and waiting with baited breath !
Well 5mm to wide .. oh well no car till next year unless my pal turns up later to help line my picasso gears up.
At least the picasso has a spare rad...,ive just checked this new rad against the picasso! :lol: Back to square one. It looks the same but just a bit to small one way and to big the other
:-D
Huskyxantia
x 909
Re: 206 Radiator
The unblock dpfwarning on dash is a software glitch its still doing it even if auto wipers is on it runs through the list on screen like its gone made lol must be some way of plugging car into computer and deleting the command for the warning my dpf is brand new
:-D
x 6945
Re: 206 Radiator
When you replaced the DPF you must tell the engine ECU that you have replaced it. Did you do this using PP2000 / Diagbox?
Huskyxantia
x 909
Re: 206 Radiator
GiveMeABreak wrote: 16 May 2022, 09:53 When you replaced the DPF you must tell the engine ECU that you have replaced it. Did you do this using PP2000 / Diagbox?
Afraid i didn't as not got the diagbox to do so, it bothers me a little but more if i was to sell the car on. I must look into this at some point the car is a real nice drive
:-D
x 6945
Re: 206 Radiator
That's why the warning will remain. You will need to sort this out as it will likely fail the MOT on some warning lights. The Engine ECU estimates how much Cerine has been dumped into the particle filter since the DPF was installed (whether new from factory or having been replaced). Cerine is found in the Eolys additive and contains particles that cannot be burned off during regeneration. It is these particles along with the other debris that ultimately block the filter. The Cerine is measured by weight. The engine ECU knows how much additive has been injected into the fuel tank each time the car has fuel added. This is how it estimates when the DPF is at end of life. So despite changing it, without telling the engine ECU, it will still think the DPF is end of life and hence the warning. It is always a good idea to top up the additive tank at the same time as replacing the DPF and reset the additive counter too.
There should be members here who have diagnostic kits that may be able to do this for you.
Have a look at our list of members who have offered Lexia / Peugeot Planet / Diagbox Diagnostics help if you haven't already seen it - link below:
At the end of the list is a link to a Google Map, showing the geographic locations of members and details. Just use the Private Message or Email links on the member's profile to contact anyone suitable.
List of Lexia / Diagbox Owners with Kits Offering Help
Bear in mind, although we update the list as often as we can, not all members are active on the Forum all the time, so it may take a while for a reply.
Huskyxantia
x 909
Re: 206 Radiator
Thanks marc , just sent a pm to a member not far from me found on the list , he was on here this morning about 9.30ish so fingers crossed.
:-D
