Re: Bargain Basement Motoring
Little more from BB Micra's trip out...straight out the camera this time. No chalk drawing manipulation with abstractness about 7 , high colour saturation and chalk flowability high
Many different effects for images available here https://www.imgonline.com.ua/eng/chalk-drawing.php
One of the more useful £100 purchases I have made... still gets the nod for the odd day out, as opposed to normal carthorse duties.
Debut on thread February 2019
https://www.frenchcarforum.co.uk/forum/ ... 89#p601889
Out and about today Regards Neil
Low sun, dirty windscreen, washer jets not working. Time to get the wire out... to sort out the blocked jets.
Very close to a Room 101 candidate in the general category "plastic clips break", and also very close to winning a "most awkward to get at" award.
Here it is hiding away recessed under the bonnet. Hitting the hole with the wire....awkward, so only the vaguest of internet instructions, push the whole assembly to one side to press on one of the clips and when it breaks remove the jets assembly.
I have to report the most successful ever poking with a wire...right through from jet to feed pipe
Dormouse
- x 696
Tip for Plastic Clips - either heat them with a hair dryer/hot air gun or run hot water on to a cloth wrapped close to them. Let the plastic heat up and you have a better chance of not breaking them.
- x 5673
Too late, too late, came the cry!Dormouse wrote: 29 Nov 2021, 16:04 Tip for Plastic Clips - either heat them with a hair dryer/hot air gun or run hot water on to a cloth wrapped close to them. Let the plastic heat up and you have a better chance of not breaking them.
Just broken the retaining clip for my daughter's C3 bonnet strut off
Bargain Basement Clio still on the maintenance fleet.
https://www.frenchcarforum.co.uk/forum/ ... 31#p559131
Windscreen Washer motor job done again, after the normal period of built in obsolescence.
viewtopic.php?p=704039#p704039
- x 5673
Out in the Micra today and had the non too pleasant experience of a rare visit to a petrol station. £20 evaporates away in quick time.
Some may say they like the smell of petrol, some may even say they love it, most people using the petrol station are probably so accustomed to it they don't even notice it.
Well believe me, Sainsburys petrol station today was full of Volatile Organic Compounds, a cocktail of benzine, toluene, xylene and the rest giving that "petrol fume" experience.
When you are filling the tank, you cant get your nose away from it, and its just there to breathe in unless you hold your breath. I put £20 in about 14 litres. That should do me for 140 miles or so.
Had a spritely drive home. I virtually never have a spritely drive in the Leaf, very much economical pootle mode most of the time, not that I mind. The Micra surprisingly is a very decent driving car with plenty enough poke, 5 gears too. Had a heater fest enjoying a heater on full blast...you take advantage of the advantage, you become very heater conscious when your main car is a low range Leaf, (even though with the heat pump on the actual loss of range is not too disastrous).
- x 8128
I may have to start a complementary thread called Penthouse Motoring!!
I also went to the petrol station today to refill after my trip to Bournemouth on Saturday. I covered 320 miles then plus another 15 on the way to the garage. My trip computer showed an average mpg of 42.3 for the tank, which I am very happy with, and as a result I expected the 44.8 litres I had to put in. I was mildly alarmed at the £73.46 bill!!
However when you break it down, the return cost of transporting us in comfort and covid isolation to and from the seaside was just £35 each. Not too bad for a great day out for my passenger and 320 miles of doing what I love the most!! How much is a ticket for a premier league football match which gives you a couple of hours entertainment, possibly enjoyable possibly not depending on the result, plus the opportunity of getting grief on the way there and back!! I think I'll stick with the penthouse!!
BBClio in Heriot Country 2018
Langthwaite Bridge
Langthwaite Bridge
Bargain Basement Clio is back for its annual MOT prep.
Today had to get a new Exhaust Rear Silencer. Sure it was only a couple of years ago it got the full exhaust done but there's a decent hole in the current silencer. Will probably have to sort the headlights out as the clear covers are now a bit opaque, maybe too opaque for the tester.
Time for another ECP/Carparts4less visitation. Not universally popular, (as James' comments testify
), but paddling about in the bargain basement and doing about 4,000 miles at most in a year I'll not be fitting Hella headlights at £260 for a pair to the BB Clio in the maintenance fleet.
I see now that as well as the free delivery with its "being in" drawbacks, you can collect your order from Carparts4less from an ECP store. So with the headlights I can order them through ECP and collect them and pay £126 or order them through Carpartsforless and collect them at the same store same time for £100.
NewcastleFalcon wrote: 05 Jul 2021, 20:42When I need to use them, I use them most of the time JamesHell Razor5543 wrote: 05 Jul 2021, 20:25 Might I suggest you steer well clear of both of these suppliers. ECP (full name Euro Car Parts) has the deserved nickname of Euro Crap Parts, and CarParts4Less is their Internet brand.. The local factors unless you are in the trade cant get anywhere near on price although I have hit lucky on some components and use the local factors occasionally after they have given me a price on the phone. Had a few incorrect oil filters shipped but in general everything has been fine. Deliver free too which makes a big difference and less hassle collecting as both outlets are over 30 miles away. Speaking as I find, they have been ok, apart from the odd wrong filter being sent.
So the choice is
I do half-enjoy a scrapyard ferret but the path of least resistance apart from my skinflintyness would be the just under £100 from Carparts4less. Could attempt a polish up myself but they are probably past it now, and the equipment/product to do half decent job would probably run to over £20 with no positive end result likely.Eurocarparts "aftermarket new" at £126.98 for a pair
Carparts4less "aftermarket new" at £99.68 for a pair
Scrapyard (if a pair of reasonably clear ones can be found travelling to the four corners of Northumberland and Durham)
I wouldn't pay more than £10 each for them, many of them will be the OEM originals, and unless kept in a darkened garage for the last 18 years will probably be as opaque as mine.
E-bay......never used it, and for such matters as second hand headlights wouldn't trust a picture as to their clarity when they arrive in a package at my door and I am not in the game of dispute resolution should they not be "as described.
