206 Radiator
- x 5615
206 Radiator
That's a lotta money for a radiator.
Last one I bought was for a Honda Accord and was 67 quid.
Reason: Topic Split from Here on out of Parts Requests
- x 7966
Re: 206 Radiator
I sometimes wonder if manufacturer's parts pricing is partially aimed at getting people to scrap older cars and hence make room in the market for new sales. Obviously the after market parts suppliers are in a different sector which helps us poor commoners keep the older vehicles on the road!!myglaren wrote: 19 Dec 2021, 10:29 That's a lotta money for a radiator.
Huskyxantia
- x 803
Re: Citroen and Peugeot Parts Requests
Ive just recovered , any one know any measurments of the rad at all
Husky.
- x 7966
206 Radiator
Judging by that price I would assume it is 3m x 5m, made from platinum and lined with gold!!
Huskyxantia
- x 803
I had one made for £30 about 20 yr ago when you see how there made too the price of todays is robbery.myglaren wrote: 19 Dec 2021, 10:29 That's a lotta money for a radiator.
Husky.
Huskyxantia
- x 803
The dpf pipe somehow came off its fixture and did the damage so today modified the pipe work with much better clearance .
Trouble is rad leaks like a tap , ive taken measurments of my fitting area and ive got as follows
Rad measure 206cc
470 heigh
340 mm width between pegs ,390mm on cowling¹ possible 400mm... these are rough but almost true. If theres any diagram with measurements that would be helpful
Rad measure 206cc
470 heigh
Husky.
- x 7966
206 Radiator
Is it not possible to remove the rad, take it to a radiator specialist and have a new core inserted?
Huskyxantia
- x 803
Not sure where there's one near me , plus its getting there aswell. christmas looming....mickthemaverick wrote: 19 Dec 2021, 15:13 Is it not possible to remove the rad, take it to a radiator specialist and have a new core inserted?![]()
Husky.
Huskyxantia
- x 803
Im seeing different rads , would you have dimensions at all for the size needed, im trying to source an after market type.GiveMeABreak wrote: 19 Dec 2021, 10:26Radiator:Huskyxantia wrote: 19 Dec 2021, 09:35 Needing the correct number for a radiator water one for my 206cc 1.6hdi. Thanks in advance..
OEM Original part: 1330N2, £429.06
Peugeot Exchange Radator: 133356, £268.68
Husky.
- x 6963
Unfortunately not. PSA have not provided dimensions anywhere for the rad. Either part number would be the correct one - and as there are no other variants (like say in the case of an alternator where there can be 20+ in some cases), they would have no need to publish the sizes. So you'll have to use the measurements from the existing one to cross reference it with.
This is invariably the issue with aftermarket parts - they may have different dimensions so can be trial and error - but reduce the incompatibility by ensuring you search on 1330N2 and look to find ones in the search that have similar dimensions to each other. If it goes toes up and doesn't fit, at least you have good reason to send it back.
admiral51
- (Donor 2026)
- x 394
Husky i do not know your exact location but if you google car radiator repairs in your area i think you will find a few old school firms that will be able to help.
Pretty sure that even in this high tech age that a phone call could actually provide a collection/delivery service
Colin
Colin
Huskyxantia
- x 803
Re: 206 Radiator
My replacement rad is due this morning ! I'm watching the tracking live and waiting with baited breath !
Husky.
Huskyxantia
- x 803
Re: 206 Radiator
Well 5mm to wide .. oh well no car till next year unless my pal turns up later to help line my picasso gears up.Huskyxantia wrote: 22 Dec 2021, 10:22 My replacement rad is due this morning ! I'm watching the tracking live and waiting with baited breath !
At least the picasso has a spare rad...,ive just checked this new rad is all the same as the picasso!
Husky.
Huskyxantia
- x 803
Re: 206 Radiator
206cc radiator measurements.
This is from my own car 2006 1.6dhi dv6
520mm inner core width
540mm outer core width
385 lenght inner core
390 top mount pegs
Sticking up small exspantion hose inlet,outlet 16mm
Width or rad complete 568mm
340mm bottom mount pegs center to center spacing
32mm outer hose connectors taken from the swollen part the pipe pushes over
24mm inner hose connectors
Sorry for any spelling mistakes im as big as eddie hall and have banana fingers too
390 top mount pegs
Husky.
Huskyxantia
- x 803
Re: 206 Radiator
Brain storm
The air con rad is out the car as it all came out in one piece to get to the radiator.. could i put the radiator in place and not use the air con rad .. Why have air con in a convertible just put the roof down..
Husky.
