Original part is no longer available, but replaced with: 1634882580. Price £20.20 inc. VAT as of posting direct from Citroen.
- x 6963
Re: Citroen and Peugeot Parts Requests
Rhothgar
- (Donor 2026)
- x 225
Lovely Marc. Not a bad price for OEM either. I don't suppose you can extract the original superceded part number can you? It's not 96145457 is it?GiveMeABreak wrote: 18 Dec 2021, 11:09Original part is no longer available, but replaced with: 1634882580. Price £20.20 inc. VAT as of posting direct from Citroen.
- x 6963
Yes that was the original part number.
Rhothgar
- (Donor 2026)
- x 225
Brilliant. Thank you ever so much as per usual Marc.
Huskyxantia
- x 827
Needing the correct number for a radiator water one for my 206cc 1.6hdi. Thanks in advance..
Husky.
- x 6963
Radiator:Huskyxantia wrote: 19 Dec 2021, 09:35 Needing the correct number for a radiator water one for my 206cc 1.6hdi. Thanks in advance..
OEM Original part: 1330N2, £429.06
Peugeot Exchange Radator: 133356, £268.68
- x 6963
Please note the general conversation re the rad has been moved (link below) - and out of parts requests.
viewtopic.php?t=70213
cs101
- x 6
Hi,Marc!
Please can you give me gearbox oil capacity for VIN VF3**************[VIN obfuscated, can be read by forum staff].
And also the part number foe the Air filter Grommets (the rubber which holds the air filter cover). Thanks
- x 6963
If changing the oil, you should measure what comes out and replace with the same quantity.cs101 wrote: 20 Dec 2021, 21:16 Hi,Marc!
Oil Capacity after emptying for DV engines:
1,9 litre (Gearbox casing with fins)
2,6 litres (Gearbox casing without fins)
Oil capacity after overhaul for DV Engines:
2,2 litres (Gearbox casing with fins)
2,9 litres (Gearbox casing without fins)
As for the Air Filter, they don't show the AF cover fixings as separate parts...
cs101
- x 6
Thank you very much, Marc.
Rhothgar
- (Donor 2026)
- x 225
M728 passed MOT with flying colours today.
Managed to get a joblot of 6 droplinks for £16.99 delivered!!!
All for M728:-
Could I please have part numbers for all central door locking mechanisms please including boot solenoid when you have a moment?
Original and latest part numbers would be very much appreciated.
Also, is there a part number for the rear boot windscreen perimeter seal (that is around the perimeter of the glass). My mate reckons it probably comes as part of the rear screen which is also probably NFP.
Time to get on top of this baby now and get her back into tip top functional condition.
All for M728:-
- x 6963
This is the door control mechanism diagram. Obviously there are too may parts for me to list all these. Let me know which items you want part numbers for:
As for the tailgate weather strip, item (17) it is available separately and still available. Part 870746, £82.34
Obviously, the glass is bonded to the vehicle, but the tailgate rubber weather strip is available as said.
Rhothgar
- (Donor 2026)
- x 225
Cheers Marc.
It would be all Part 1 in the top picture that I would like for each door.
I am not sure that strip is the one I am looking for as I think Part 17 goes around the edge of the panels when the tailgate is open. I am looking for the weatherstrip that goes around the perimeter of Part 4 tailgate glass especially looking at the cross section of Part 17. That looks like the seal that seals between tailgate and car body panels not tailgate glass to Part 1. Fingers crossed it is on a glass fiche?
- x 6963
Doors:
Front
Right 9136J6 (1 Plug) £146.88
Right 9136H9 (2 Plug) £160.24
Left 9135H1 £146.88
Rear Door Locks Rear
Left 913744 (2 Plug) £173.62
Right 913859 (2 Plug) No Longer Available.
Rear Windscreen
So no, there is nothing else shown. The glass is bonded - just like the front windscreen. The only trims are item (2) left and right for the sides, but nothing else.
Front
Left 9135H1 £146.88
Rear Windscreen
Huskyxantia
- x 827
Marc, when convenient for you i need as follows
Part number for dpf sensor and pipe position from dpf to sensor
Thank you.
Thank you.
Husky.
