Peugeot 207 fault code P1490, P242F
207Peugeot14
- (Donor 2021)
I've been having issues with fault codes, my cars a 207 1.4hdi 2011 vin number VF3**************[VIN obfuscated, can be read by forum staff]
P1490
P242F
P2563
I have changed the turbo actuator position sensor and that has sorted code P2563 out.
So this morning while quite on the roads i decided to take it for a drive to encourage it to do a regeneration but unfortunately this did not happen as fault code P242F came up putting the car into limp mode.
I cleared this and tried again with no joy.
My car normally does a regeneration every 220 miles and is currently now 185 miles into that cycle, after this mornings 55 mile drive trying to encourage a regeneration.
Any advice would be greatly appreciated thanks.
P1490
P242F
P2563
- x 6963
Re: Peugeot 207 fault code P1490, P242F
Here are the fault descriptors - so your particle filter likely needs replacing or being professionally cleaned.
The turbo fault may well be caused as a result of back pressure in the exhaust system because of the DPF blockage.
I would recommend a professional cleaning service for your DPF, as they use special chemicals and equipment to deep clean these if you are considering this, or just have it replaced.
| Fault Code: | P1490 |
| Description of Fault: | Particle filter: Detected overloaded. The fault is triggered when Volume flow rate passing through the particulate emission filter above 0,025 m3/s (90000 l/h). Possibility 1 For a volume flow passing through the particle filter of 100000 l/h, the differential pressure is greater than 60 mbar for 5s Possibility 2 For a volume flow passing through the particle filter of 400000 l/h, the differential pressure is greater than 230 mbar for 5s Possibility 3 For a volume flow passing through the particle filter of 800000 l/h, the differential pressure is greater than 450 mbar for 5s |
| Conditions for Fault to clear: | Driving for 5 minutes |
| Downgrade Modes whilst Fault is active: | Deactivation of the request for regeneration of the particle filter from the diagnostic tool |
| Symptoms: | No effects immediately perceptible. |
| Suspect Areas: | Particle emission filter clogged or over-loaded |
| Fault Code: | P242F |
| Description of Fault: | Particle filter: Detected clogged. The following have to be in effect for the fault to be triggered:
For a volume flow passing through the particle filter of 100000 l/h, the differential pressure is greater than 320 mbar for 5s Possibility 2 For a volume flow passing through the particle filter of 400000 l/h, the differential pressure is greater than 700 mbar for 5s Possibility 3 For a volume flow passing through the particle filter of 800000 l/h, the differential pressure is greater than 770 mbar for 5s |
| Symptoms: |
| Fault Code: | P2563 |
| Description of Fault: | Turbocharger: Position incorrect in relation to the setting, too much turbo. The position measured is less than the reference by more than 20% for 4 seconds. The following conditions have to be met:
| Downgrade Modes whilst Fault is active: | None |
| Symptoms: |
| Suspect Areas: |
207Peugeot14
- (Donor 2021)
Thanks Marc
207Peugeot14
- (Donor 2021)
Hi
I took your advice and called a dpf cleaning company who wanted to charge £460 to clean it.
Somewhat reluctant to spend that sort of money, i decided to think about it.
And in the meantime my car done a regeneration, and all warning lights turned off by the car.
Approximately around 14 miles later "risk of particular filter clogging" flashes up and after a few times stays on the dash.
Got to work and done a live scan and to me the dpf does not look like it's anywhere near being blocked. The fault code I'm now getting is P1490 only no other codes.
Please see images below of the live scan on tick over and then at 2500 rpm
On a side note for some reason i do not get email notifications for my threads even though I've ticked the box...
- x 1466
If you click through the fault code, what info does it say about conditions when it occurred? In the pics above the oxygen sensor is reporting an invalid value - not sure if this is fitted, or if it even needs to give a reading normally!
207Peugeot14
- (Donor 2021)
Hi
Here are a couple of pictures from that same code on Sunday morning,
Unfortunately i did not take pictures this morning but if need be i will plug in to get them and report back,
- x 6963
Also, according to that it says the particle filter has already been changed 19k KM ago???
The differential pressure shows as 059 mbar. The differential pressure sensor is designed to show the range of differential pressure measured as 0 ? differential pressure measured ? 100 kPa on this engine / system (1.4 DV4C).
059 mbar is 5.9 Kilopascals, so this would seem to indicate the system is nowhere near blocked.
- x 6963
Just seen you other pictures. Can you please advise what units 4000 on the particle filter additive load is please?
207Peugeot14
- (Donor 2021)
Hi Marc
Hence my confusion as to it being blocked, as I'm not sure how you read these scans, but by what I've looked up it appears it's no where near blocked,
But clearly the car does have an issue,
I changed the elroys fluid sometime ago and reset the counters but was still having this problem so it was suggested that i also told the cars ECU that the DPF had been replaced/cleaned even though it has not been.
Apparently this can sometimes help clear the fault but in my case it did not.
207Peugeot14
- (Donor 2021)
Sorry I am not sure what i think is i will plug it in again and get the full code information sorry for the hassle gents, once i have it i will upload itGiveMeABreak wrote: 07 Dec 2021, 10:08 Just seen you other pictures. Can you please advise what units 4000 on the particle filter additive load is please?
207Peugeot14
- (Donor 2021)
Ah just found it on my Sunday morning scan it is in MgGiveMeABreak wrote: 07 Dec 2021, 10:08 Just seen you other pictures. Can you please advise what units 4000 on the particle filter additive load is please?
- x 1466
You've got 242 mbar at a flow of 66 l/s ( 237600 l/hr) - this would appear to be why it has set the code. Given that the pressure sensor appears to be working, it does appear to be a genuine fault. It would be worth graphing the pressure over a short run, along with the air flow to see if there is correlation. It could be a fault with the MAF giving shonky readings, but I'm leaning towards the DPF needing a clean. You can do it yourself with dishwasher tabs and brick acid - there's a vid somewhere I posted about it!
207Peugeot14
- (Donor 2021)
Thanks Richard please can you explain how i get this information with diagbox as I've no idea, sorryRichardW wrote: 07 Dec 2021, 11:28 You've got 242 mbar at a flow of 66 l/s ( 237600 l/hr) - this would appear to be why it has set the code. Given that the pressure sensor appears to be working, it does appear to be a genuine fault. It would be worth graphing the pressure over a short run, along with the air flow to see if there is correlation. It could be a fault with the MAF giving shonky readings, but I'm leaning towards the DPF needing a clean. You can do it yourself with dishwasher tabs and brick acid - there's a vid somewhere I posted about it!
207Peugeot14
- (Donor 2021)
Is this the video RichardRichardW wrote: 07 Dec 2021, 11:28 You've got 242 mbar at a flow of 66 l/s ( 237600 l/hr) - this would appear to be why it has set the code. Given that the pressure sensor appears to be working, it does appear to be a genuine fault. It would be worth graphing the pressure over a short run, along with the air flow to see if there is correlation. It could be a fault with the MAF giving shonky readings, but I'm leaning towards the DPF needing a clean. You can do it yourself with dishwasher tabs and brick acid - there's a vid somewhere I posted about it!
viewtopic.php?t=67304&start=15
- x 6963
Yes that's the reading we were missing 242 Mbar... so in zone 'b' - overloaded.
"A" : Differential pressure (mbar).
"B" : Volume flow rate of exhaust gases (l/h).
"a" : Intermediate zone.
"b" : Filter overloaded.
"c" : Filter clogged.
