Citroen picasso c3 1600 t diesel 2012
my fuel additive pump was broken few months ago , and after i fixed it it showed me a waring of -risk of filter clogging , and water in diesel filter.
now after i put the new pump with fluid in place (like a month ago) , the risk of filter clogging is gone , (i cleaned the dpf filter also) ,
and the water in diesel filter warning still realy bugging me.
i have tried to disconnect the connector of the water in fuel! filter sensor but it still popps , and some time it can beep for a few minutes in a row....
any advice?
c3 picasso Water in diesel filter
- x 6957
Re: c3 picasso Water in diesel filter
These have to be bled after replacing the fuel filters
piki
- x 5
how?
i bled the fuel filter with this button on top of filter housing .
that what u referring?
i couldnt see any option how to get rid of water in the filter
- x 6957
There is a procedure for replacing the Fuel Filter and for the bleeding / water in Diesel. I've put it in the Member Resources Section:
C3 Picasso 1.6 HDi 92 (DV6DTED) Fuel Filter Replacement / Bleeding
piki
- x 5
it says im not authorised to read this forum.
- x 6957
The Resources section is for members that have made a donation (which also provides you with live parts information and parts diagrams for up to 2 years) so good value. Details below:
If you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
piki
- x 5
hi
so i changed the filter , and bled it , it still warns me ,
maby its not the water in fuel filter (warning is -water in diesel filter).
and how could it be the sensor if it throw the warning also when the sensor is unplugged??
