Huskyxantia
- x 900
Re: Citroen and Peugeot Parts Requests
Cheers marc, ill take a run to the main dealer tomo, see whats what cheers for the part numbers its a big help.
Husky.
- x 6956
Ok keep us posted and bear in mind they may have stock or may need to order them in.
Huskyxantia
- x 900
Sure will thanks again for your help
Husky.
207Peugeot14
- (Donor 2021)
Excellent thanks Marc
407
- x 22
407 hdi 2.7l oil pressure sensor and location
After an oil and filter change, a few days later I'm getting a oil low pressure warning at idle
Goes away when over 1000 rpm and normal driving
Oil is full (used 10-40w as we are in a hot climate)
Filter (paper cartridge) was a Coopers WC0107 Manns
I suspect the oil pressure sensor but have read it could be the oil pickup screen (assume it has one) being dirty
can I get a part number plus a location diagram
Vin is VF3**************[VIN obfuscated, can be read by forum staff]
thanks
thanks
- x 6956
Here you go:
(8) Oil Pressure Switch, part: 1131H8, £49.36
(6) Oil Filters:
OEM, Part: 1109AW, £16.03
PSA Cheaper: E149235, £16.32
(6) Oil Filters:
- x 22
thanks as always
what else could go wrong, eh
thanks as always
- x 6956
I've moved your Injector question out of 'Parts Requests' to the main technical Forum - here:
viewtopic.php?p=703611#p703611
randomandy
Could I have the part number for the rear shock absorbers for the Peugeot 207 VIN: VF3**************[VIN obfuscated, can be read by forum staff]
-Andy.
-Andy.
- x 6956
@ Andy:
The originals parts are no longer available, so PSA are recommending part 5206 QC as an alternative for this vehicle. These of course must be replaced in pairs. Priced at £66.11 each.
Alternatively, they offer a cheaper version, part: 1623315080 priced at £50.34 each.
dan g
- (Donor 2021)
Clutch part number please
Can someone help with part numbers for 5008 egs clutch kit inc. dmf please.
Vin VF3**************[VIN obfuscated, can be read by forum staff]
Dan
Dan
Reason: Moved to Citroen Peugeot Parts Requests
- x 6956
@dan:
Clutch Kit Item (1)
OEM Clutch Kit: 2052Z1, £424.22
DMF Item (10)
Original New: 0532W4, £844.30
PSA Reconditioned: 1613938280, £501.02
Or Complete Kits Item (12)
Item (12):
Part: 1631733780 (CLUTCH AND DMF PRO KIT IF CLUTCH BEARING 2041A3, £1,205.38
All VAT Inc. direct from Peugeot
Clutch Kit Item (1)
DMF Item (10)
Item (12):
dan g
- (Donor 2021)
Thank you Marc
dan g
- (Donor 2021)
Hi Marc
Item 12, full kits.....is the third set using csc 2041A3 the only set with a csc using a clutch position sensor.
The 1st and 2nd non sensor csc ? Can you check please.
Dan
Dan
- x 6956
Hi Dan - I've double checked and as your thrust bearing (in the first diagram) item (3) is part 2041A3, the only full kit that includes this specific thrust bearing kit is 1631733780.
I have removed the first 2 options from my previous post as they won't be relevant.
