Hi all,
I have a Citroen Xsara Picasso 1.6 Petrol, 2009 with a suspected broken timing belt.
I bought the car on Sunday (4 days ago) from a private seller and drove the car home some 150 miles without a problem. Picked my kids up from school, no problem. Driving Wednesday evening (yesterday) and the car lost all power and the engine just "spins" too freely when trying to start. I haven't had a chance to look at it yet, but I suspect a broken cambelt.
I've been doing some bedtime reading and it doesn't look too bad a job on a petrol engine. But I did see a video where someone said you should get a new camshaft as the lobes are press on and can move with a cambelt failure. I've only heard that on this one video, so just wanted to check with everyone.
This forum has been a great resource already and you all seem a really friendly bunch
I can't believe my luck with this car. I had a megane before but the clutch failed so I bought this Citroen
Thanks,
Graham
Suspected broken cambelt - Citroen Xsara Picasso
- Location: London near that big building with the flashing light!
- My Cars: 2001 Xsara Picasso 2.0 HDi
- x 8
Re: Suspected broken cambelt - Citroen Xsara Picasso
Didnt happen to buy From Exeter or Exmouth? and it's red? via eBaygbk71 wrote: ↑25 Nov 2021, 09:36 Hi all,
Thanks,
Graham
The 1.6 diesel models have pressed on cam lobes but i dont think the petrol ones are.
- x 8
Guy did say about belt as way way over due we had looked at it but left it as another thing was ringing bells! before sorting head out check the front cross member/suspension is in line as friend is thinking been off road into something?
Also check rear arms.
- My Cars: Citroen Xsara Picasso 1.6 Petrol, 2009
OK thanks. It drove fine on the way back home. The invoice had "Timing belt?" written on it from the last service so I'd been researching what was involved and had it planned for a couple of weeks time. Oh well. Hopefully it won't be too bad.
Does anyone know what engine it would be? Code wise. It's a "Desire" 1.6 from 2009. But I keep seeing 8v and 16v 1.6 petrol for parts and I don't know what it is. I'm guessing 8v. If it was 16v it would probably have another badge on the back!
I would think a 2009 model would be 16v. Dont think the picasso ever came with 16v badges.
A pic of the engine or the VIN number will confirm.
- x 8
If put reg up can check. But Citroen don't use badges like that just name rank and serial number! ie Citroen.Xsara Picasso Desire/Exclusive then you just pick out what engine/fuel/size it is from there!gbk71 wrote: ↑26 Nov 2021, 09:19 OK thanks. It drove fine on the way back home. The invoice had "Timing belt?" written on it from the last service so I'd been researching what was involved and had it planned for a couple of weeks time. Oh well. Hopefully it won't be too bad.
I took the cover off over the weekend - it's a 16v. Got 2 cams with the lobes pressing directly on the valves, no rockers.
I'm assuming there are bent valves. Is there an easy way to check? Just wondering if I should put a new belt on and just try it. Or go straight for a full head removal. Bit of a step in the dark for me. Done lots of tinkering - carb rebuilds on old golfs, suspension fixes etc but taking these engines apart will be new
Reg number is WU09 WHZ.
Looking at ECP, they've got 2 kits available one says it's for "134 teeth, 25.4mm", the other is for "engine TU5JP4, 134 teeth, 26mm".
Would the VIN be helpful? Is it OK to post here?
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5726
Just for reference - If you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum. |
To Upgrade Your Membership & Donate Click Here For Further Information About Vehicle Parts and VIN Numbers Click Here |
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
Please consider avoiding ECP. Although some people have not had issues with them, others have (and there are a few horror stories out there). ECP have 'earned' the nickname "Euro Crap Parts". GSF are usually considered to be better, and (if you sign up on their website) there can be decent discounts available.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Your engine is a TU5JP4 (NFU)
When i put that reg into ECP it gives 2 choices 101 teeth & 17mm wide or 134 teeth & 26mm wide.
Best to measure the width & count the teeth on the one you have.
Yes, avoid ECP junk, i can only imagine the quality of a timing belt that costs £4.48
Even the citroen aftermaket one is nearly 10 times that & a genuine original citroen one is £105 Thats just for the belt alone, no tensioner or idlers.
