Flood
Huskyxantia
x 904
Flood
Unread post by Huskyxantia »
Got caught in flood water had to be recovered stripped the injectors out the way and spun the engine over by hand out came the water, 20 mins later it fired back into life and has been running fine since.
Low air duct, i need a mod any ideas.?
Went for a swim
Went for a swim
:-D
x 5673
Re: Flood
Check your air filter - I had similar when my wheel arch liner exploded and the intake sucked a lot of spray and muck from the verge in.
Filter was soaked and the housing full of water and grit. MAF was ruined too.
Air filter housing
Air filter housing
MAF
MAF
Huskyxantia
x 904
Re: Flood
Im not getting notifications of any replys ...
Wow that did take some mucky stuff in , i was luck the water was clean, i took the injectors out disconected the glow plugs and turned thd engine over by hand , with the glow plug relay fuse removed and injectors back in i used easy start to get it fired up ,then switched it off put relay fuse bsck in restarted and let it run and warm up. The water that came out the exhaust !!!
3 weeks later i replaced the glow plugs with one snapped tip which i got out with glow plug tip remover kit , all new bosch ones running ok now. ALL that and no warning light on dash
:-D
x 7164
Re: Flood
Pleased its back running well, and you succeeded in getting the broken glow plug out.
Had a similar experience documented on here a few years ago, the eventual result was...
Glow plugs Annihilate Xsara Picasso 2.0 HDi
Story here should anyone wish to read
https://www.frenchcarforum.co.uk/forum/ ... hp?t=54768
Gregor
x 16
Re: Flood
Unread post by Gregor »
Picasso submarine by Citroen! :) They don't make that good anymore! :)
Driving Citroen is a diagnose!
Huskyxantia
x 904
Re: Flood
Gregor wrote: 18 Nov 2021, 12:23 Picasso submarine by Citroen! :) They don't make that good anymore! :)
should of got me a yellow one !😆
:-D
x 1454
Re: Flood
Unread post by xantia_v6 »
Huskyxantia wrote: 18 Nov 2021, 08:13 Im not getting notifications of any replys ...
Check your notification preferences here: ucp.php?i=ucp_notifications&mode=notification_options
And your watched topics here: ucp.php?i=ucp_main&mode=subscribed
