Help required Identifying what 207 gear linkage cable
- x 6945
Re: Help required Identifying what 207 gear linkage cable
Ok, so the cables are not available separately. Part (1), the gearshift control lever comes as a whole unit including the cables.
The part is: 2400JZ and they are £274.25 inc. VAT direct from Peugeot, as of this post.
Be very careful with ebay as some sellers are charging more than the dealer for a new one!
207Peugeot14
- (Donor 2021)
Wow that's amazing thanks very much for that, do you know how to remove the cables from the gearstick housing ball joint at all please
- x 6945
I'll have to put something together for you - it will take me 30 minutes or so.
207Peugeot14
- (Donor 2021)
Marc your a gent thanks
- x 6945
Ok, so here you go, it's in the Members resources section:
207 5 Speed Manual MA Gearbox Control Cable Removal / Replacement
207Peugeot14
- (Donor 2021)
Marc that's excellent many thanks for your help it's much appreciated
- x 6945
No worries.
- x 1055
Check local motor factors or ebay, You should be able to get a set of cables (without having to buy the gearstick as well) for way cheaper than the crazy dealer price. I done a set on a C4 mentioned earlier in the thread & the aftermarket ones were about a third of the dealer price.
randomandy
The temporary fix I applied in August (following my previous posts) has now failed and one of the cables has snapped. Given the car is 14 years old I want to try to find a cheap set of cables on an auction site!
Trying to figure out which are the correct ones for VIN VF3**************[VIN obfuscated, can be read by forum staff] if someone could tell me what the official part number is.
-Andy.
PS - As per the above comments, just made a donation.
-Andy.
- x 6945
Hi Andy
Yours is slightly different:
The gear cables on this box (2) are available separately, part: 2444CZ
They are £228.58 inc. VAT from Peugeot as of this post.
randomandy
If my detective work is correct then that would make this https://www.ebay.co.uk/itm/234129430864 ... SwbFdhEQmp the correct part.
- x 6945
Don't rely on ebay parts database! Just search the part number and you'll come up with plenty of options:
https://www.ebay.co.uk/itm/303089628919 ... 9628919%3B
Just make sure it is part 2444CZ or equivalent. If you check with the seller you will at least have some comeback if they confirm this.
- x 6945
This Borg & Beck one lists the correct part further down:
https://www.ebay.co.uk/itm/293480399064 ... OSw09peSjy~
£66 ish too!
£66 ish too!
b0riz
- New User
Hi!GiveMeABreak wrote: 17 Nov 2021, 21:18 Ok, so here you go, it's in the Members resources section:
Hope you still read this forum. I am new registered member. I really need this link you posted, but i can not read it. How can i get accsess to it?
Boris
- x 5672
That info is in a forum area that is restricted to members who donate to the forum, the reason being that PSA now charge for such information. the forum has a paid for account with PSA supported by members who donate.
Your donation allows two years of access to such information, through the forum.
Link to donate if you wish to proceed with that.
