I Phone issues with MyWay / WIPNAV
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
admiral51
x 392
Re: I Phone issues with MyWay / WIPNAV
Unread post by admiral51 »
Marc be gentle with me if i need to go deeper into Diagbox functions to alter other stuff :rofl2:
And thanks again for the help :-D
Colin
admiral51
x 392
Well i think i have managed to get everything back up and running. [-o<
Replacement head unit now in place, all firmware up to date and all configurations set to those from the original unit and Vin coded to the car :-D
And not only that the phone is working correctly again so the good lady is happy ( well for a short while ) :rofl2:
Only issue i have is that the sat nav thinks it is in Cardiff but fingers crossed that will sort itself out once it has been driven for a while, only seeing 1 satellite at the moment. [-o<
Thanks for all the help much appreciated
Colin
x 6958
Nicely done Colin.
admiral51
x 392
I couldn't have done it without the help you have given me Marc but also the forum is a vast library of knowledge and just reading through posts gave me the confidence to do it, as i have mentioned many times Tech and myself are not best of bed fellows but step by step i am getting better :)
And a happy SWMBO is something that cannot be measured in words :rofl2: :lol:
Colin
x 6958
I'm sure Mrs Colin will be very pleased!
:dom:
admiral51
x 392
Just a final update on this one [-o<
Everything is working 100% as it should, the sat nav has now got its bearings and knows where it is :-D
I know it pays to shop around but i think i got a bargain in getting the replacement head unit for £120 :rofl2:
Colin
x 6958
Well done! Hard to say what the cause was - could be a the GPS tuner, the internal flash storage giving up - but at least you know where you're going now!
admiral51
x 392
Hi Marc
Just posting here as i think my problem with the audible indicator warning maybe down to me not setting the parameters correctly when i swapped the head unit over.
I am 99.9% sure i set everything correctly but i was wondering if you could take a look back at the pictures i posted in this thread of the screenshots in case you think something looks wrong or if as the head unit is from a newer vehicle there is a parameter in another ECU i need to change.
Not sure if you can get any info from the vin but have updated the thread in the Citroen section about swapping head units back if that makes sense.
Colin
x 6958
I've had a look Colin, my notes below:
1st Screenshot. The correct settings for the items I have listed are 'Absent' not 'Missing'. If you can change to Absent I would do so.
Heating Ventilation (change to Absent)
Parking Aid - Absent
Under Inflation Detection - Absent
Screenshot 2 - All Correct
Screenshot 3 - All Correct
Screenshot 4 - All Correct
Screenshot 5 - All Correct
Screenshot 6 - N/A
So it's not any of these settings, unless the change to Absent for the first 3 items makes a difference Colin.
admiral51
x 392
Hi Marc
I have just tried to change the settings and it does not show Absent for any of the 3.
The odd bit on the Heating/Ventilation setting option screen it says must be set to Absent if it has a dedicated A/C panel but i do not get the option to set it to Absent.
Is it possible my version of DB 7.58 is not upto reading the newer head unit correctly, or more to the point not giving me the correct options ?
Colin
x 6958
I've checked the change logs Colin and there is no mention of any issues regarding the C5 concerning this specific area. It may be a faulty module in the car, but temporarily replacing the old unit may provide a clue if it is this or not.
admiral51
x 392
Thanks Marc
Out of curiosity could you find a diagram/location price of the module just so i can maybe give the Good Lady a few days to calm down and rejoin the rest of us on Planet Earth :)
Weekend i will swap the old unit back but have a gut feeling on this one lol
Colin
x 6958
As far as I can tell the speaker unit is in the switch module - most likely item (1) - Multifunction Control Module. Item (2) is the VMF Integral Switch Module which handles all the steering wheel controls.
Sitting Down? Maybe wise to give Mrs Colin a few weeks, I'm not sure a few days will cut it!
Item (1) 6242 RG, £426.97
Item (2) 98030642ZD £499.46
So really important to confirm this is the fault. Of course, if the switch module needs replacing you'll need to have the steering wheel angle sensor calibrated too, or the ESP system will throw a wobbly Colin.
admiral51
x 392
Thanks Marc
Guess the Steering Angle Sensor is a Dealer only job :cry:
:hb: :hb: :hb: :hb: :hb: :hb: :hb: :hb: :hb: :hb: :hb: :hb: :help2: :help2: :help2: :help2: :help2: :rofl2: :rofl2: :rofl2: :rofl2:
Colin
x 1878
Setting the Steering Angle Sensor is actually fairly simple providing you have a Lexia/Diagbox. Basically, it's a matter of making sure that when the steering wheel is in the straight ahead position that the angle registered is 0. If it isn't then change it to zero.
