Citroen c5 multiple warning lights
stevenplace4
Unread post by stevenplace4 »
Hi. I am having a multiple warning lights coming up on my dashboard. They seem to appear at low speed or when braking luckily because the engine shuts down aswell. I can start the engine straight after it cuts out and it drives fine and all the warning lights are gone. I can then drive for 1 hour or 1 day and so on and then they return. They are never the same sequence or same faults, I have had it in 4 different garages now with different results. The first garage which is who I use all the time told me it was the engine fuse box but he could not carry out the work and recommended a auto electrician. I then took it to auto electrician, he told me the battery needed renewing which he changed and it seemed fine for a couple of days then the problem returned. I took it back to him and he was to busy to fit the car in.
I then took it to another recommended auto electrician and suspected a fault on the wiring loom. He had it for 3 weeks. He told me he found the fault on the loom and repaired it. 10 minutes after leaving the garage it lit up like a Christmas tree and cut out. Please help
x 6947
Re: Citroen c5 multiple warning lights
It is true that the engine fusebox may be the culprit - however as you are plainly seeing, taking it all over the place to different garages is probably costing you and not helping very much.
It needs proper diagnosis using bespoke diagnostic tools, so for this sort of potentially dangerous issue I would get it to Citroen and start saving time and money.
This sort of issue that causes catastrophic failure is likely to be a loss of power at the main fuse box / supplies unit or related wiring.
stevenplace4
OK thanks for the advice. I'm running out of options so looks like I will have to bite the bullet and take to main dealers
x 6947
Yes, there' should be one right near you (SB Wakefield) - it's where I bought my C5 X7 a good few years ago - great place and friendly staff.
Gregor
x 16
Unread post by Gregor »
take a look on rotation sensors! They often cause similar issues. Mine and my friens C5X7 had this simptoms. In bolth cases sensor on crankshaft (pos sensor) was falty. Cheap and easy to replace. Garage also wanted to change fusebox....
Driving Citroen is a diagnose!
stevenplace4
Thanks Gregor. I will try that
Gregor
x 16
Keep us posted!
x 1240
Unread post by Peter.N. »
Try connecting a voltmeter to the cigar lighter socket and place it where you can see it when driving. It should read around 14.4 volts but if it varies much from that when the fault occurs it might help with the diagnosis. If it drops very much when the fault occurs it will be a general supply fault, if not it will be an individual unit supply that's failing.
If it is, you could try connecting it to different supply feeds maybe starting at the fusebox.
x 5675
These are cheap-ish and easy to get hold of.
Not this particular one of course.
I had one in the C5 when my alternator started to fail. Broke it though.
Another posher one has appeared in the Civic - my son's to charge his phone more than anything, despite there being a dedicated USB port.
x 1240
Not seen one of those - but then I don't get out much. :(
x 5675
Peter.N. wrote: 21 Oct 2021, 23:48 Not seen one of those - but then I don't get out much. :(
Me neither but the internet is a useful resource - bought mine from eBay and Amazon, as with so many things.
x 1240
Never come across one on 'tinternet but then I haven't been looking for one - useful though!
x 1943
There was one stuck in the cigar lighter when we bought the MGB. I transferred it into the 308 to keep an eye on the voltage produced on the overrun.
Over the last 12 months the first digit (normally displaying a 0 or a 1) has gradually lost all the segments of the display but it's still useable - you just have to use your imagination to add the most likely first digit!
