C5 x7 cigar lighter 12v sockets
- (Donor 2021)
- My Cars: 2012 Citroën C5 Tourer Exclusive 2.0 HDI 160 Auto
2011 Citroën DS3 So Chic 1.6 VTi 120 Auto
2019 Citroën C4 Cactus 1.2 'Feel' Turbo Auto
1991 Mini 1.0 Special - x 2
The 12v sockets on my C5 Tourer are disconnected when the ignition is off.
Is there a jumper or something that allows me to have them permanently connected, like in some Mercedes models?
I’d like to be able to connect a solar battery charger to the car when we leave it for long periods.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: C5 x7 cigar lighter 12v sockets
No, it's for protection of the system and is BSI controlled to switch off.
You would need to wire it up directly to the battery I suspect, but make sure that the negative of the solar charger is connected to the Battery Charge Status Unit on the battery negative cable and not the terminal itself, otherwise it can affect the monitoring of the battery condition / health.
- Dormouse
- My Cars: Peugeot 3008 Hybrid4, Fiat Ducato, Morris Mini.
plus notable cars I have owned :- Studebaker 1921, Daimler Consorts, Mercedes 220 Pontoon, Simca 1301, Austin Metropolitan, lots and lots of Minis, both steel and fibreglass bodied, Fiat 500F, Citroen GSA's, Skoda Estelle 120 Rally replica, DKW 1000S, Triumph Herald Estate, Warwick GT (very briefly) - x 666
Could you put an image up for what this looks like on the negative connector please. I want to do the same on Pint Pot. thanksGiveMeABreak wrote: ↑09 Oct 2021, 13:26 No, it's for protection of the system and is BSI controlled to switch off.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I'll need to check if you have one on your Van - pop the VIN up for me.
- Dormouse
Back to the old bogey Pint Pot is a Fiat - vin u/s! But if I use Diagbox as a Boxer and insert the vin manually, it works.
Some kind of generic image for the C5 would do and I could probably figure it out.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
What year / engine has it got?
- Dormouse
It is a 2008 model Puma engine 100 Multijet and is the same basic spec as all the 3000kg base models
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Have a look at my post here:
viewtopic.php?p=645801#p645801
This is on a C5 X7 - they tend to be on cars from 2008 onwards, but may not be on your VAN.
- Dormouse
cheers. will start ferreting.
Some of the solar trickle chargers come with a 16 pin OBD socket connector & you can just plug it directly in there as there is a battery live & earth.
There are plenty of plugs available on ebay that you could use to make a lead up.
https://www.ebay.co.uk/itm/262782690314 ... SwUKxYZEfL
- Dormouse
Good thought. I already have a use planned of the obd so I would need some kind of piggy back or double obd plug. But it has set me thinking about "inventing" a connection via the obd as it can connect solar chargers correctly.
- Gregor
- My Cars: Actual fleet:
- C5 III tourer 2.0 HDI RHF (103kW 2010)
- P208 XY 1.6 THP (115kW 2013)
- GSX-R 750 (110 kW 2008)
Past members:
Xsara 2.0 VTS (2001)
P206 1.4 XS (1999)
AX 1.1 (1991)
R 5 GT-turbo (1988)
Visa 11 RE (1984)
GS 1.3 Super (1979)
R 12 TL (1975)
Zastava 750 (1968) - x 14
Socket in the boot is always active in my tourer 2009... check yours.
Driving Citroen is a diagnose!
Again, no shortage of choice when it comes to Y cables for doubling up the OBD socket.
Just search for OBD Y cable on ebay.
- Dormouse
The socket goes off with the ignition and Y splitters are an option if I can securely mount them so cables don't get strained. Currently hunting down OBD bulkhead fittings.
Will post up what I do in my camper thread
