C5 x7 cigar lighter 12v sockets
Post Reply
Sebastian Tombs
(Donor 2021)
My Cars: 2012 Citroën C5 Tourer Exclusive 2.0 HDI 160 Auto
2011 Citroën DS3 So Chic 1.6 VTi 120 Auto
2019 Citroën C4 Cactus 1.2 'Feel' Turbo Auto
1991 Mini 1.0 Special
Post by Sebastian Tombs »
The 12v sockets on my C5 Tourer are disconnected when the ignition is off.
Is there a jumper or something that allows me to have them permanently connected, like in some Mercedes models?
I’d like to be able to connect a solar battery charger to the car when we leave it for long periods.
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5742
Re: C5 x7 cigar lighter 12v sockets
Post by GiveMeABreak »
No, it's for protection of the system and is BSI controlled to switch off.
You would need to wire it up directly to the battery I suspect, but make sure that the negative of the solar charger is connected to the Battery Charge Status Unit on the battery negative cable and not the terminal itself, otherwise it can affect the monitoring of the battery condition / health.
Dormouse
(Donor 2022)
My Cars: Peugeot 3008 Hybrid4, Fiat Ducato, Morris Mini.
plus notable cars I have owned :- Studebaker 1921, Daimler Consorts, Mercedes 220 Pontoon, Simca 1301, Austin Metropolitan, lots and lots of Minis, both steel and fibreglass bodied, Fiat 500F, Citroen GSA's, Skoda Estelle 120 Rally replica, DKW 1000S, Triumph Herald Estate, Warwick GT (very briefly)
x 666
Post by Dormouse »
GiveMeABreak wrote: 09 Oct 2021, 13:26 No, it's for protection of the system and is BSI controlled to switch off.
Could you put an image up for what this looks like on the negative connector please. I want to do the same on Pint Pot. thanks
C15 Romahome White
CX 20 Polar White
x 5742
I'll need to check if you have one on your Van - pop the VIN up for me.
Dormouse
(Donor 2022)
x 666
Post by Dormouse »
Back to the old bogey Pint Pot is a Fiat - vin u/s! But if I use Diagbox as a Boxer and insert the vin manually, it works.
Some kind of generic image for the C5 would do and I could probably figure it out.
C15 Romahome White
CX 20 Polar White
x 5742
What year / engine has it got?
Dormouse
(Donor 2022)
x 666
Post by Dormouse »
It is a 2008 model Puma engine 100 Multijet and is the same basic spec as all the 3000kg base models
C15 Romahome White
CX 20 Polar White
x 5742
Have a look at my post here:
viewtopic.php?p=645801#p645801
This is on a C5 X7 - they tend to be on cars from 2008 onwards, but may not be on your VAN.
Dormouse
(Donor 2022)
x 666
Post by Dormouse »
cheers. will start ferreting.
My Cars:
x 733
Post by wheeler »
Some of the solar trickle chargers come with a 16 pin OBD socket connector & you can just plug it directly in there as there is a battery live & earth.
There are plenty of plugs available on ebay that you could use to make a lead up.
https://www.ebay.co.uk/itm/262782690314 ... SwUKxYZEfL
Dormouse
(Donor 2022)
x 666
Post by Dormouse »
Good thought. I already have a use planned of the obd so I would need some kind of piggy back or double obd plug. But it has set me thinking about "inventing" a connection via the obd as it can connect solar chargers correctly.
Gregor
My Cars: Actual fleet:
- C5 III tourer 2.0 HDI RHF (103kW 2010)
- P208 XY 1.6 THP (115kW 2013)
- GSX-R 750 (110 kW 2008)
Past members:
Xsara 2.0 VTS (2001)
P206 1.4 XS (1999)
AX 1.1 (1991)
R 5 GT-turbo (1988)
Visa 11 RE (1984)
GS 1.3 Super (1979)
R 12 TL (1975)
Zastava 750 (1968)
x 14
Post by Gregor »
Socket in the boot is always active in my tourer 2009... check yours.
Driving Citroen is a diagnose!
My Cars:
x 733
Post by wheeler »
Again, no shortage of choice when it comes to Y cables for doubling up the OBD socket.
Just search for OBD Y cable on ebay.
Dormouse
(Donor 2022)
x 666
Post by Dormouse »
The socket goes off with the ignition and Y splitters are an option if I can securely mount them so cables don't get strained. Currently hunting down OBD bulkhead fittings.
Will post up what I do in my camper thread
Post Reply
