fake I.F.H.S sphere
x 1459
Re: fake I.F.H.S sphere
Unread post by xantia_v6 »
Where the sphere bleeds or squirts LHM after being removed, it is because the diaphragm has a small hole, and the space in the sphere which normally contains only nitrogen now contains a mixture of nitrogen and LHM. When the pressure is released, it takes a while for the nitrogen/LHM mix to be pushed through the hole in the diaphragm until the pressure is equalised.
saeedm
x 16
Unread post by saeedm »
so by loosening sphere charging bolt ,there will be some LHM, if diaphragm is perforated.
x 1746
...only if LHM has managed to get through/past the diaphragm.
You can usually tell if the diaphragm is perforated if you try to re-gas it: pressure will not hold,
saeedm
x 16
i found a original ifhs sphere!!
but it is for hydractive models -regarding to ifhs catalog-. can i use it for non-hydractive?
its have good threads and dampers and comes with ifhs box - pack of 2 -
also have spotted numbers on damper
