Hi there,
I have a 2013 Citroen DS5 and the Start/Stop button has completely peeled off, and gives the interior a very bad look. I bought a new button and cant find anything online about how to replace it.
I don´t want to break anything.
Please help?
DS5 Stop Start Button
- My Cars: 2013 Citroen DS5 1.6
Reason: Moved to DS Section
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: DS5 Stop Start Button
Do you have the ECO button with a bank of other switches, or the Stop Start switch immediately under the analogue clock?
Just the Start/Stop under the clock
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
You will need a set of these keys - that you can buy cheap enough off ebay or other places - they are the same ones used for removing some Head Units.
First you should disconnect the battery following the relevant part of this guidance: BSI Reset / Battery Disconnect / Reconnect Procedure
Refitting
Proceed in the reverse order to removal.
Reconnect the battery following the reconnection part of the BSI Reset / Battery Disconnect / Reconnect Procedure
Check the operation of the equipment.
Unclip the analogue clock (1) (at "a") using tool [1287]. Detach the analogue clock (1). | Disconnect the connector (at "b"). Remove the analogue clock (1). |
Remove:
| Unclip the multifunction control panel (3) (at "c") using tool [1287]. Detach the multifunction control panel (3). |
Disconnect the connectors (at "d"). Remove the multifunction control panel (3). |
WOW. Thanks a billion.
I´ll let you know if it worked.
Do you have the steps on replacing the media control switches in the center console?
