what a lovely datsun...
Bargain Basement Electric
dave
- x 17
Re: Bargain Basement Electric
- x 694
Neil - I wonder if you have had any problems with the front driveshafts clicking on your Leaf?
Try turning the heater and pedestrian warning off so the car is silent, pull away slowly, listen for a click from the front when you apply power and another click when you apply the brake pedal to apply regen. For this to work you probably need to be <80% SoC so that you have full regen.
I think mine has been doing this very slightly since I've had it but it has got noisier now, and it turns out this is a very, very common problem with Leaf's with lots of reports on speakev and elsewhere, and there is also at least one Nissan service bulletin regarding it.
As mine is out of original car warranty I've been trying to find out exactly what the cause and cure is as I don't fancy paying Nissan to do it especially when many people have reported that after Nissan "fixed" it the click has return...
There is a lot of hearsay and misinformation about this issue but what I've been able to find out so far is that it is caused by the hub nut being inadequately torqued causing the stub axle to rock slightly on the spline in the hub...
Where it gets interesting is that the original hub nut torque figure is a crazy low 121Nm !! Compare this to a Xantia where the hub nut is torqued to 320Nm... The first Nissan bulletin addressing this issue was released some time around 2013 and yet some brand new 2020 62kWh Leaf's are still having this issue within 6 months.
In the original bulletin they tell you to remove the hub nut, push the stub axle partially out the back of the hub, apply molly grease to the rear part of the spline and hub and refit it with a new nut/washer (on models that have a washer) and torque back up to the same 121Nm figure...
But after doing some digging it appears that the recommended torque figure has been retroactively updated to 185Nm... also it seems there are at least two stub axle variations for different age Leaf's - some have a stub axle with a cut out keyway and use a stake nut to lock the nut after tightening it, while others have a normal shaft and nut with a nut cap and cotter pin. Not sure which my car has yet!
Anyway, thought I would bring it to your attention. I'm going to have a look at mine and see if I can tighten it up to 185Nm to see if that fixes the clicking...
- x 7163
Thanks for the heads up Simon.Mandrake wrote: 03 Jun 2021, 11:09 Neil - I wonder if you have had any problems with the front driveshafts clicking on your Leaf?
In all my driving so far I have never consciously noticed it Simon. Air/con heater never in action these Summer days other than a quick flick if we are steaming up. I have never knowingly recognised the passenger alert noise either.
I fear now that I will be unable to shut out the possibility of a click should there be one to hear. Case of turn the radio up and carry on unless I feel some serious wheel wobble, or some humming, whining or groaning bearings.
- x 7163
- x 7163
On a drive to get some hacksaw blades
- x 7163
- x 7163
Electric motoring on a sunny afternoon in Northumberland
- x 7163
Probably the steepest descent the BB Leaf has encountered in our Ownership, down to Scotland's first Harbour on the East Coast.
Spent 2p on fuel for the journey as told here
https://www.frenchcarforum.co.uk/forum/ ... 07#p693907
- x 7163
Somewhere in the Summertime since the Start of August when the mileometer was at 43,403, BBleaf has lost one of its 12 bars. Its battery in the 19 months of our ownership has done 15,000 miles of very gentle treatment.
So 43,500 miles and 6 years is the point at which the State of Health of the battery of the BB Leaf drops to 85% of the original capacity of the pack. The first bar loss represents 15% loss, subsequent bar loss represents 6.25% further loss.
I would have liked to keep the 12 bars longer, but the loss of capacity is inevitable with age, and charging cycles.
- x 7163
BB Leaf goes to Scotland...through the window in the Scottish Borders
- x 5662
No haggis & thistles, could be anywhere.
- x 7163
The old BB Leaf isn't entirely Maintenance free. With the MOT coming up in September, discs and pads need a bit of attention. The nearside rear was giving the graunch of pads worn down to the metal so the job has started.
Its an odd set up on the leaf the rear disk is a disk and drum combined, with a handbrake and brakeshoes acting on the inside of the disk, and your normal caliper and pads on the outside. Its a mechanical handbrake (foot operated) operating on the little shoes inside the disk.
- x 8074
That is a fairly common arrangement these days Neil, especially on Japanese cars. I was surprised to discover the Kia Venga does not have that arrangement!!
- x 7163
With a normal handbrake arrangement operating on the rear wheels where there are disks on the rear wheels, the pistons on the caliper have to be wound back. I cant quite work out whether the Leaf ones do or not. Nissan say use a piston rewind tool but I cant see any connection at all between the caliper and the handbrake mechanism which is a cable operated thing acting via a lever on the shoes.mickthemaverick wrote: 28 Aug 2021, 19:09 That is a fairly common arrangement these days Neil, especially on Japanese cars. I was surprised to discover the Kia Venga does not have that arrangement!!![]()
Any thoughts?
- x 2941
Common Volvo and Saab set up Neil.
