C5 2.2 HDi VTX
TonyMont
- New User
C5 2.2 HDi VTX
I'm really hoping someone can help me with this. I have a leaking rear right hand suspension cylinder. My garage has taken the car for its MOT and it has failed. We have tried to get hold of a replacement cylinder (part No. 527271) but have got nowhere and been told that they aren't manufactured anymore. I have also tried to get a seal repair kit but again I have been told that these have also been discontinued. I have just spent quite a bit on the car, which I love, having the clutch replaced and the timing belt as that was due, yet this problem might be the sadly end of the road. Otherwise the car drives perfectly and has 168,000 miles on the clock which is testament to its high quality. Does anyone have any ideas?
OnlineHell Razor5543
- x 3299
Re: C5 2.2 HDi VTX
Hi, and
to the Forum. Another member had issues with rear suspension cylinders, and came up with this;
viewtopic.php?t=46231
MGmike
- x 63
Re: C5 2.2 HDi VTX
If leaking from the other end try here for seals https://www.eurocarcare.net/search/finder/73-203/ but you'll need to ensure you get the correct size as there are two... You'll also need a new gaiter and pin.
Failing that it's a replacement from a car being scrapped..
