2004 c5 hdi 110 cooling fan woes FIXED and now running (pg 6 on) .
citroenxm
- Fallen Hero
- x 70
Re: 2004 c5 hdi 110 cooling fan woes and now not running....
Probably not as the plugs are sealed.. The only way to get at the pins is to unplug them..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
MGmike
- x 63
OK, I guess you need to take the plunge and replace the ECU...
But before you do... and to get the car running again I would fit one of these:-
https://www.carbuilder.com/uk/mini-add- ... use-holder
and connect the bullet to a switched 12v supply with a length of suitable wire. The easiest point to pick up a switched live will be the wiper feed cable which is one of the big ones on the two pin grey connector in the middle of the BSM. That will need you to strip a bit of the insulation to get a connection or disconnect the connector and plug in to the cable for now.
If you are happy to use a permanent 12v to get the car running you can pick that up on the cable bolted to the the BSM 13mm nut at front centre.
citroenxm
- Fallen Hero
- x 70
OK Mike...
Thankyou for your time you have spent looking at the wiring diagrams trying to sort things out.
There's a cheap ecu and bsi on ebay for 40 quid.. Which is too good to miss really.
Just out with the car.. Applying 12v to the supply wire for the pump DOES activate the pump... So the pump isn't at fault.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 3302
Is it possible there is an air leak in a diesel line? Maybe, with all of the work on the cooling fan you have been doing, you have knocked a fuel line? I would imagine that, once the fuel pump has primed the system, the natural engine action would then pull fuel from the tank if all of the pipes were 'tight'.
citroenxm
- Fallen Hero
- x 70
OK. A new chapter..
I have just applied 12v permanently to make the pump run constantly.. And I could hear the pump running too.. And started the car.. And.. Would you guess it.. Same response it stalls..
Time to get lexia on I think.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
No I cannot see that happening there's pleanty of push in the pump.. I connected my volt meter up to read what the pump supply does.. After the engine starts the volts do climb but very slowly. So I thought.. Yea permanently put 12v in.. But no same problem engine still stalls.
Cam and crank HAVE to be in sync other wise it would not fire up so I can't see it being the crank sensor.. I'm still leaning to wards engine ecu
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
Well here's a number of interesting faults...
Let's do a clear and see what happens..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
Ooooo I can't clear them... I can read etc..
But when I goto erase faults. Lexia reports Communication problem..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
MGmike
- x 63
Interesting... how and where did you connect the 12v?citroenxm wrote: 20 Jul 2021, 10:59 OK. A new chapter..
citroenxm
- Fallen Hero
- x 70
I put it at the supply cables at the bsm socket..
Just looking in lexia.. Fuel pressure regulator is showing a current of 2388.5mA... I think that's a bit high..
I think I'll double check the bsi fuses. Its strange lexia can't clear ecu faults
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
OK further lexia tests. I went into cooling fan actuator tests.. High speed fan good.. Cooling fan works.. Low speed fan... Different story..
The bsm buzzes and the fan doesn't work.. And I also did fuel line pressure tests.. The 3rd.piston was fine but the pressure regulator test produces exactley the same symptom as the low speed fan test..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
MGmike
- x 63
do you mean you pulled the pump fuse out and connected in to the pump side without the fuse in?
MGmike
- x 63
That's not a big surprise as I think they are supplied by the same relay in the BSM. Put your replacement BSM in and see if the test results change.citroenxm wrote: 20 Jul 2021, 11:31
citroenxm
- Fallen Hero
- x 70
Nothing changes.. All bsi fuses are OK..
So I think I must be looking at an ecu issue.. Its strange I cannot erase engine ecu faults..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
Yes... And out of interest I did it with the fuse in too.. And still the same..
I'm lexia you can do a supply relay test... I did this and the relay and fuel pump pulsed on off on off as normal.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
