peugeot 3008 hdi 2017 dpf fault
david2000
hi to all
hear is an update on my previous topic had diagnostics done on the car today and they told me that there was a fault with communicateing with the dpf fuel tank on the can bus diagnostic circuit has anyone had this fault and does anyone have a wiring diagrame for the dpf tank
david
david
- x 6956
Re: peugeot 3008 hdi 2017 dpf fault
I don't David, sorry, not for a 2017 DV6FC.
- x 1485
david2000
hi to all
a new tank has been fitted now my question is does the dpf tank connect to the bsi interface
david
david
- x 1056
The additive tank normally has a LIN connection to the BSI.
david2000
hello wheeler
what colour is the LIN connection and i have been told that there is a common fault on the peugeot and citroen with the wiring for the additive tank
david
david
- x 1056
PSA dont use wire colour coding, they use codes printed on the wiring.
If it is the type of tank with the 3 pin plug pin 2 is normally the LIN connection.
Are you getting no communication with the tank?
david2000
hello wheeler
yes
yes
- x 1056
First check is to confirm you have a power supply & earth across pins 1 & 3.
david2000
hello wheeler
12v is this correct
12v is this correct
- x 1056
Yes, you should have battery voltage across pins 1 & 3 with the ignition on.
david2000
hello wheeler
there is 12 v across 1 & 3 what next
david
david
- x 1056
To check it properly you would need a wiring diagram to check the LIN wire between the tank & the BSI, I suppose you could also scope the wire & see if there is anything going down it. If you have physically checked the wire as far as you can the chances are you need a new tank/pump unit. Certainly not uncommon.
david2000
david
david
- x 1056
Just to confirm was it a brand new genuine part?
