peugeot 3008 hdi 2017 dpf fault
Post Reply
david2000
My Cars: peugeot 3008
Post by david2000 »
hi to all
hear is an update on my previous topic had diagnostics done on the car today and they told me that there was a fault with communicateing with the dpf fuel tank on the can bus diagnostic circuit has anyone had this fault and does anyone have a wiring diagrame for the dpf tank
david
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5741
Re: peugeot 3008 hdi 2017 dpf fault
Post by GiveMeABreak »
I don't David, sorry, not for a 2017 DV6FC.
My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl
x 1003
Post by RichardW »
This is similar... may need a new tank :shock:
viewtopic.php?t=65736
david2000
Post by david2000 »
hi to all
a new tank has been fitted now my question is does the dpf tank connect to the bsi interface
david
My Cars:
x 733
Post by wheeler »
The additive tank normally has a LIN connection to the BSI.
david2000
Post by david2000 »
hello wheeler
what colour is the LIN connection and i have been told that there is a common fault on the peugeot and citroen with the wiring for the additive tank
david
My Cars:
x 733
Post by wheeler »
PSA dont use wire colour coding, they use codes printed on the wiring.
If it is the type of tank with the 3 pin plug pin 2 is normally the LIN connection.
Are you getting no communication with the tank?
david2000
Post by david2000 »
hello wheeler
yes
My Cars:
x 733
Post by wheeler »
First check is to confirm you have a power supply & earth across pins 1 & 3.
david2000
Post by david2000 »
hello wheeler
12v is this correct
My Cars:
x 733
Post by wheeler »
Yes, you should have battery voltage across pins 1 & 3 with the ignition on.
david2000
Post by david2000 »
hello wheeler
there is 12 v across 1 & 3 what next
david
My Cars:
x 733
Post by wheeler »
To check it properly you would need a wiring diagram to check the LIN wire between the tank & the BSI, I suppose you could also scope the wire & see if there is anything going down it. If you have physically checked the wire as far as you can the chances are you need a new tank/pump unit. Certainly not uncommon.
david2000
Post by david2000 »
david
My Cars:
x 733
Post by wheeler »
Just to confirm was it a brand new genuine part?
Post Reply
