Citroen nemo 1.3 s/s
- (Donor 2021)
- My Cars: Citroen Nemo 1.3 multispace s/s
Re: Citroen nemo 1.3 s/s
Hi, out of interest can anyone tell me on diagram A where the connector for the sensor on timing chain/oil pump is ?
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5723
Do you mean the Camshaft Position Sensor? If so Item (3) and Engine Speed Sensor is (1)
- (Donor 2021)
No it’s electro valve at the bottom of the timing chain cover which goes into oil pump I need to know the connector on the diagram ‘A ’because not sure if my harness has one even though my new timing cover/pump has , my old cover/pump doesn’t , hope that makes sense!!!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I can't help you there - the diagrams are not structured like that. That was the engine harness and it doesn't tell you what each plug goes into. There's no sensors or plugs on the timing diagram either - so I'm not sure what it is you are looking for.... nor on the engine oil pump chain belt suction diagram:
- (Donor 2021)
Hi, can you check what the correct part number is for my car for timing chain/ fuel pump (item A and 1 in pic ) I have been told there is 2 types depending on if your car has stop/start version?? Regards Paul.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Timing Chain:
Original Part: 0816K9: £71.38
Now replaced with Part No: 1634846880: £204.86
High Pressure Fuel Pump:
Original OEM: Part No: 1920SJ: £1310.52
or there is a Bosch one listed, Part No: 1679595580 (OD C15884 BOSCH CODE 0445010311): £1222.96
or there is a cheaper equivalent listed (lighter and less CO2 used):
1623821280: £519.78
1623821280: £519.78
- (Donor 2021)
Sorry my mistake I need part number for oil pump not fuel pump regards Paul
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Apologies - The server didn't update as I was looking at a part for another member for a C4 Picasso
I've deleted the last 2 posts to avoid confusion for others in future.
Part is item (1) and:
Original Part Number: 1001G7: £195.55
Now superseded with Part number: 1606466880: £300.73
- (Donor 2021)
Will this fit stop/start 1.3 because when I look up that part number it’s only suitable for a non stop start engine and that’s what a parts supplier said , getting very confused ??
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
You have the 'F 13DTE5 FAP 55KW 1248 4C' engine - but beware there are 2 types of oil pump for this engine -one for 'Normal' and one for 'Optimised' fuel consumption - and they have different parts numbers.
1606466880 is the correct part number for your vehicle - hence why we use the VIN - Aftermarket / Third Party parts suppliers / breakers do not always understand the subtle differences in parts.
- (Donor 2021)
Thanks for that now I know why my timing cover/ oil pump doesn’t fit
