Citroen nemo 1.3 s/s
Post Reply
Pac238
(Donor 2021)
My Cars: Citroen Nemo 1.3 multispace s/s
Post by Pac238 »
Hi, I am new to the forum but can someone help me, I need part number for the engine wiring loom for Citroen nemo 1.3 multispace 2011 it’s a stop/start model reg v11 oex, thanks Paul.
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5742
Re: Citroen nemo 1.3 s/s
Post by GiveMeABreak »
Hi and welcome.
Please see below for parts info requests: A min £10 Forum donation will provide you with parts requests for up to 2 years as this info is chargeable by PSA. If you want to go ahead, details below and then please provide your VIN (Automasked).
A response to your question by a Forum Admin will require detailed vehicle information that requires you to have made a current contribution to the Forum.
Donate
Further Information
Pac238
(Donor 2021)
Post by Pac238 »
Hi, I have now donated as requested, cheers
My Cars:
x 733
Post by wheeler »
That doesn’t seem to be a correct reg number you provided.
Pac238
(Donor 2021)
Post by Pac238 »
Sorry it’s LV11 OEX
My Cars:
x 733
Post by wheeler »
Vin is VF7**************[VIN obfuscated, can be read by forum staff]
Pac238
(Donor 2021)
Post by Pac238 »
Are you asking me for vin number?
C15 Romahome White
CX 20 Polar White
x 5742
No he's just provided it from your registration so I can find the correct part for you - just hang on a moment...
My Cars:
x 733
Post by wheeler »
Pac238 wrote: 19 Jun 2021, 10:46 Are you asking me for vin number?
No sorry, i got your correct reg from your PM so just converting to VIN to enable parts look up.
C15 Romahome White
CX 20 Polar White
x 5742
So you'll need to tell me which harness you want as there are are different harnesses depending on what you want:
(A) This is the Main Engine Harness Diagram(B) This Diagram Shows the Under Bonnet Wiring.
The Diagram in Table A is the Injector Harness (1).
The Diagram in Table B is the Main Harness (1) excluding the Injector Harness above.
Let me know which one you need.
Pac238
(Donor 2021)
Post by Pac238 »
Thanks Marc, it’s the injector harness I need !
C15 Romahome White
CX 20 Polar White
x 5742
Ok, so the original part number for the injection harness was 6585N9 but this was replaced with an updated harness, part: 6585R0. The 6585N9 part is therefore no longer available from Citroen.
6585R0 is £890.82 from Citroen, inc. VAT.
It attempting to locate a seconf hand harness, I would try and stick to the later part to avoid issues.
Pac238
(Donor 2021)
Post by Pac238 »
Thanks for that ! wow Citroen certainly know to charge , secondhand part will be the way to go if I can find one ??? Any idea were I can get one from ?
C15 Romahome White
CX 20 Polar White
x 5742
Ok, so you'll just have to 'Google' those part numbers - but most of these will be from foreign sites from the looks of it.
The markings on the wiring are shown as:
ZF55231079 or ZF55232840
Pac238
(Donor 2021)
Post by Pac238 »
Cheers again👍🙂
Post Reply
