C5 X7: Inner tie rods
j001
Unread post by j001 »
Hi guys,
I want to change tie rods, I got this tool:
But in servicebox they use also another tool (see attachment). Is it necessary? Do I need this tool also? Do I risk damaging something by not using it? I haven't seen such thing in any tie rod removal videos.
x 6945
Re: C5 X7: Inner tie rods
It's to prevent damage to the steering mechanism during the slackening-tightening of the track rod. If it wasn't required, they wouldn't be using it officially...
j001
So finally I changed only outer tie rods, just in case, inner tie rods look still ok. Do you know where I can buy the tool shown on the second pic? I cannot find such a thing. Thank you.
osx
(Donor 2022)
x 15
Unread post by osx »
Thinking of changing them too as I get steering wheel vibration only when turning right and only when I accelerate at the same time.
Can't by tyres as I don't get vibration under any other circumstances and have changed them anyway.
I was concerned about the lower ball joint but every mechanic that has checked the car was happy this is not the cause.
Driving shaft - again checked and no issues and would probably get some vibration when accelerating irrespective of steering wheel position.
Anything else that hasn't been eliminated yet?
C5 X7 Exclusive 2.0 HDi Auto
RoofsUp
Unread post by RoofsUp »
osx wrote: 06 Feb 2022, 11:58 Thinking of changing them too as I get steering wheel vibration only when turning right and only when I accelerate at the same time.
Wondering if you got this problem solved, i've got the exact same problem when steering right and applyng torque to the wheels (giving it some juice)
A loud vibration noise comes from the left side. Top and lower cv-joints have been replaced. Now doubting the tie-rods.
But i've read one of your posts stated it was fixed when replacing the entire strut. Which seems strange to me as mine has been done 2 years ago..
PaulC5
x 693
Unread post by PaulC5 »
Maybe the outer cv joint on the left drive shaft is worn (not the ball joints which you appear to have changed but called cv joints). How many miles (km) has it done ?
x 1995
Unread post by Stickyfinger »
The lower joint(frip) is the one I would look at first, it cannot be "tested" without lifting the cars wheel off the ground and then use a pry bar to see if there is movement.
Many mechanics do not know about this joint or how to test it.....your symptoms seem to be common for that joint (they have a shortish life)
aerodynamica
x 215
Unread post by aerodynamica »
Hi, I'm looking for advice on this same issue. I posted here viewtopic.php?t=84767
But I see the second photo in the original post in this thread had the Citroën tool you must use to hold the steering rack before attempting removal of the track inner rod.
I've searched generally to see if I can find this but to no avail. Anyone know if there's a psa tool number for this?
If it is not available how are non dealers supposed to remove the inner track rod..
Graeme M
