Hi all, hopefully someone can help me.
I have a citroen c4 1.6hdi 110 that seems to love to throw problems at me recently. I've had the turbo go only a month ago, but that's another story for another time.
I believe my gearbox is going bad. I've heard some rather unhealthy noises coming from it and 3 gear has been more than a little crunchy to shift down in to.
At present, I have the car up on some wheel ramps to reattach the undertray and decided to use this as an opportunity to get the gear box code to try and locate a replacement. There's a high chance that it has a slow leak of oil on the nearside driveshaft, but I can't be sure that it isn't just residual oil from the turbo and water from the lovely weather we've been having in Blighty.
I've had a good look at the gearbox and haven't been able to see the code anywhere on the underside of it even after a quick clean with some brake cleaner and a wire brush.
I'm hoping that someone here might be able to shed some light on the correct box for my car. My vin is: VF7**************[VIN obfuscated, can be read by forum staff]
Id greatly appreciate any help with getting the right code for it. Love my little coupe and want to keep it running as long as I can!
Cheers,
C4 coupe, 1.6hdi gearbox model number.
Jameshezzy
- (Donor 2021)
- x 6955
Re: C4 coupe, 1.6hdi gearbox model number.
Hi James.
I can help you with official part numbers, but as we are charged for this data, we ask for a £10 min. Forum donation for this, which will cover your for up to 2 years of parts requests and parts diagrams.
I have the VIN from your post, so if this will help details and links below:
| A response to your question by a Forum Admin will require detailed vehicle information that requires you to have made a current contribution to the Forum. |
| Donate Further Information |
Jameshezzy
- (Donor 2021)
donated. Much appreciated for the help!GiveMeABreak wrote: 22 May 2021, 18:39 Hi James.
A response to your question by a Forum Admin will require detailed vehicle information that requires you to have made a current contribution to the Forum. Donate
Further Information
- x 6955
Hi James
All sorted - it must of been while we had a brief server issue last night.
I'll sort the info for you momentarily.
- x 6955
Here you go:
"a" location of engraving of serial and gearbox numbers.
"b" Identification label.
A brand new gearbox will be part number: 2222LL (£5,910.23)
An Exchange Gearbox will be part number: 2333RK (£2,148.71)
Prices are for new or Exchange as noted above direct from Citroen including VAT, for info.
The code should be: CP 19X72
Markings will be either: DM75, DM7E, DM6J or DM69 for the new one or:
DMF9, DM75, DM7E, DMG5 or DM69 for an exchange.
I hope this helps.
I hope this helps.
Jameshezzy
- (Donor 2021)
Marvellous! Thank you so much!
- x 6955
No worries, sorry about the delay. Any other part numbers you need, just ask.
