Hi
I have a rneg becker. Would anyone know where to download firmware for this unit.. its works fine but only has french snd no options to change language
Rneg firnware
- x 6955
Re: Rneg firnware
A firmware update won't fix that - the options for System Language, Date & Time, Display, Vehicle, Units & System Info are all accessed from pressing the SETUP button.
What version of firmware are you currently on - use the options above to go into the System menu and that should provide the firmware version.
Prf1
Re: Rneg firnware
Hi Marc
Many thanks for your reply. There are no options in the system menu. They appear to be missing except for date and time. Its a used radio I bought. I am not sure of the current firmware.
I just thought that reloading firmware would give me back the options.
- x 6955
Re: Rneg firnware
Ok so are you 100% sure you have the MyWay and not the RT6 eMyWay?
They look the same except that the MyWay has an SD Card slot on the front bottom middle of the unit see below.
The reason I ask is that the condition you describe is generally associated with the eMyWay after a major firmware update, that requires a dealer visit to reconfigure the unit. Until this has been done, the unit will be missing that menu I described. This will be the first time ever I have heard of this happening on a MyWay RNEG though.
Prf1
Re: Rneg firnware
Hi Marc
Its a rneg made by becker. It has the sd card slot in the front. I have diagbox.. can i reconfigure with that ?
- x 6955
Re: Rneg firnware
Highly unlikely. Have you coded your VIN to the replacement unit yet?
Normally the loss of the menu is when a firmware update has been done or the configuration has been lost.
Normally with the RT6, this needs the dealer doing in internet connected mode with technician log in to PSA servers, as the ECU goes into secure mode and cannot be unlocked without a log in.
Prf1
Re: Rneg firnware
Yes , vin coding is fine , all working except missing menu. Its not in the car anymore, had to get a replacement because of the language. Was hoping it was a case of reloading software.
Anyway, thanks for your input and advice
- x 6955
Re: Rneg firnware
In this case, it will very likely need a dealer visit to re-enable the menu unfortunately. They charge in the UK about £60 for a diagnostic - which should be ample time to do the configuration for you.
ivan985
Re: Rneg firnware
I really need help. My Rneg, like this on picture, have problem with reseting. Every time when reset it lose clock and date. That happend in drive every time, my battery is new. I want if anyone have firmware update link, i will be very thankful.
- x 6955
Re: Rneg firnware
What is your existing version?
If the unit is resetting, be aware that the flash memory may be failing.
ivan985
Re: Rneg firnware
how to check current version! Let me mention that I also have a diagbox!
- x 6955
Re: Rneg firnware
Hold the SETUP button in until the menu appears. Scroll through the options until SYSTEM appears. Select this and then there should be options that show you the software versions.
ivan985
Re: Rneg firnware
Now i will install r50.3, it was r40. I will fallow few days how it work
