Rneg firnware
Moderator: GiveMeABreak
Rneg firnware
Hi
I have a rneg becker. Would anyone know where to download firmware for this unit.. its works fine but only has french snd no options to change language
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5647
Re: Rneg firnware
A firmware update won't fix that - the options for System Language, Date & Time, Display, Vehicle, Units & System Info are all accessed from pressing the SETUP button.
What version of firmware are you currently on - use the options above to go into the System menu and that should provide the firmware version.
Re: Rneg firnware
Hi Marc
Many thanks for your reply. There are no options in the system menu. They appear to be missing except for date and time. Its a used radio I bought. I am not sure of the current firmware.
I just thought that reloading firmware would give me back the options.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Rneg firnware
Ok so are you 100% sure you have the MyWay and not the RT6 eMyWay?
They look the same except that the MyWay has an SD Card slot on the front bottom middle of the unit see below.
The reason I ask is that the condition you describe is generally associated with the eMyWay after a major firmware update, that requires a dealer visit to reconfigure the unit. Until this has been done, the unit will be missing that menu I described. This will be the first time ever I have heard of this happening on a MyWay RNEG though.
Re: Rneg firnware
Hi Marc
Its a rneg made by becker. It has the sd card slot in the front. I have diagbox.. can i reconfigure with that ?
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Rneg firnware
Highly unlikely. Have you coded your VIN to the replacement unit yet?
Normally the loss of the menu is when a firmware update has been done or the configuration has been lost.
Normally with the RT6, this needs the dealer doing in internet connected mode with technician log in to PSA servers, as the ECU goes into secure mode and cannot be unlocked without a log in.
Re: Rneg firnware
Yes , vin coding is fine , all working except missing menu. Its not in the car anymore, had to get a replacement because of the language. Was hoping it was a case of reloading software.
Anyway, thanks for your input and advice
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Rneg firnware
In this case, it will very likely need a dealer visit to re-enable the menu unfortunately. They charge in the UK about £60 for a diagnostic - which should be ample time to do the configuration for you.
- Lexia Available: Yes
- My Cars: Citroen c5 x7
Re: Rneg firnware
I really need help. My Rneg, like this on picture, have problem with reseting. Every time when reset it lose clock and date. That happend in drive every time, my battery is new. I want if anyone have firmware update link, i will be very thankful.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Rneg firnware
What is your existing version?
If the unit is resetting, be aware that the flash memory may be failing.
Re: Rneg firnware
how to check current version! Let me mention that I also have a diagbox!
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Rneg firnware
Hold the SETUP button in until the menu appears. Scroll through the options until SYSTEM appears. Select this and then there should be options that show you the software versions.
Re: Rneg firnware
Now i will install r50.3, it was r40. I will fallow few days how it work
