XM LHM Filter Clip Part Number
wesacosa
- (Donor 2021)
- x 3
Hi
Would anyone be able to tell me the part number of the little clip which holds the LHM filters in place on a 1997 XM. Mine seems to be missing. Wondering how critical it is to have one, and if they are still available
thanks
thanks
- x 1056
Re: XM LHM Filter Clip Part Number
If you talking about the little S shaped clip (number 9) the part number is 527107 but is showing as no longer available from Citroen.
- x 1751
Yes, the part is now NFP, but was fitted to the hydraulic reservoirs in all BX, Xantia and XM.
Anyone breaking one of these (eg EathanR - viewtopic.php?p=683148#p683148 ) should be able to help.
Otherwise it's a matter of looking at the classic Citroen specialists, such as citroenclassics.co.uk, Chevronics, Westroen, etc.
Alternatively, you may just be able to make one from a piece of wire, as it's a simple enough clip.
Filters just need holding securely in place; they are not under any significant pressure.
Sorry, but I can't find a photo of that specific bit.
wesacosa
- (Donor 2021)
- x 3
thanks. yes that was the part I was thinking of. hmm. that's not good its not available anymore
Out of interest what is part 4
OnlineHell Razor5543
- x 3306
Try asking citroenxm for that part. He has a lot of spares, and what have you got to lose?
admiral51
- (Donor 2026)
- x 391
Have you in the very very recent past done a LHM change and filter clean ?wesacosa wrote: 16 May 2021, 12:37 Hi
thanks
It can get lost even if you know it is there, it could be in the tank itself if a previous owner has had the job done.
It is not much bigger than a paper clip so easy to get dropped into the tank if caught when removing the filter housing .
Colin
- x 6956
Part 4 is the Hydraulic Reservoir Block Plug - also not available from Citroen.wesacosa wrote: 16 May 2021, 15:44 thanks. yes that was the part I was thinking of. hmm. that's not good its not available anymore
wesacosa
- (Donor 2021)
- x 3
Hmm I don't think I see where part four would even go. I didn't see the clip in the tank but I did see a little disc
- x 1751
If you google "LHM reservoir filters" > images. lots of pics there of the innards.
(The older circular steel reservoir (BX etc) has exactly the same central gubbins.)
One of the pix there throws up this link to a post here:
viewtopic.php?p=365057#p365057
Click on the link in that post, to see a photo of CLIP #9.
Good, innit?
Good, innit?
wesacosa
- (Donor 2021)
- x 3
Cheers. I had a good look in the tank and so far as I can see its not there, although its a bit difficult to see due to that baffling in the tank. I assume that doesn't come out. I guess if I swill some petrol around inside it might get it if its stuck in some gunk behind those baffles
- x 1751
Better to remove the tank and wash it out (petrol) several times, so all the grot comes out.
- x 3306
And you might even get lucky and find that clip in the grot!white exec wrote: 16 May 2021, 21:58 Better to remove the tank and wash it out (petrol) several times, so all the grot comes out.
wesacosa
- (Donor 2021)
- x 3
tank is already out, nothing dropped out when I tipped it upside down but haven't swilled out with Petrol yet so fingers crossed its stuck in the slop somewhere!
- x 5671
Maybe a magnet will fish it out.
wesacosa
- (Donor 2021)
- x 3
yeah good call. will give it a go.
