Sadly I may have a leaky front strut on my sisters C5. I was hoping it would have just been the return pipe but after issuing instructions and pictures I’m told it is more serious than that.
I called Pleiades about a strut refurbishment and they said that they couldn’t be overhauled. Is this true? I wasn’t sure if they didn’t do the overhaul or if it was impossible.
Thankfully Edwards & Sons have some second hand ones in stock at not a bad price.
Last question: are there just two types of Mk. 1 C5 strut? Hydractive 3+ (Sports button equipped) and Hydractive (no button)?
C5 Mk. 1 Strut Refurbishment?
- Donor 2023
- My Cars: 1987 Volvo 480 ES
2006 Citroen C6 3.0 petrol Exclusive - x 48
1987 Volvo 480 ES
- Donor 2023
Re: C5 Mk. 1 Strut Refurbishment?
Found these guys from Poland but on C6owners.org two guys say their repaired units were leaking in 6 months!
https://nagengast.pl/en/kategoria-produ ... oen-c5-en/
1987 Volvo 480 ES
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Hi James, the front struts for the MK Is are all the same, it's the rears that are different as well as the left and right obviously that are different.
Part 5271H4 Left Strut
5271H5 Right Strut
Both no longer available from Citroen as you are probably aware.
5271H5 Right Strut
- Donor 2023
Okay, good to know.
So is the difference between Hydractive 3+ cars and Hydractive cars in the strut head “B” in the previous figure? Is “strut head” the correct name?
The head is rusty on one side so it seems like a good time to change it. Sod’s law has the leak on one side and the rusty head on the other.
Are you able to provide the removal & installation instructions from the Citroen manuals?
Also, without a Lexia, the pressure is going to need to be dumped manually after putting it on low setting. What is the best way to do this?
1987 Volvo 480 ES
- My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE - x 2508
There are some used ones on Ebay but they're not cheap.
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
The rear struts are different depending on H3 or H3 plus, but it is the Sphere pressures that are also different and the addition of centre spheres for H3 plus models.
So the round saucers are referred to as suspension spheres. Although a Lexia is preferred to fully depressurise the system, the front and rear axles can be depressurised manually.
There is probably a guide I have put up previously, so I’ll locate it and edit this post with a link shortly.
- white exec
Just found these...
https://www.aliexpress.com/item/32961250997.html
The Chinese are building a few Citroens these days...
Maybe better than nothing?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, so Here is the Strut removal guide for the MK I and MK II:
viewtopic.php?p=620555#p620555
I included in this guide above the depressurisation for the Hydractive 3 only (as that was what the member had), but you can find the depressurisation for BOTH systems in this link: Just follow the bit for the H3+ system.
viewtopic.php?p=562756#p562756
