This probably is posted in the wrong section but I couldn't find an obvious place to put it.
A lot of bolts on my Dispatch are 'inverse torx' so you'd need a female torx socket.
What sizes should I be looking for in a set? The caliper bolts are a similar size to a 14mm hex and the subframe are larger. Looking online I have no idea what the sizes refer to?
Cheers
Tool advice
- moizeau
- My Cars: 91 BX TZD Estate. Dead but loved
407 HDI 136 auto
C4 2l petrol coupé
2010 Dispatch III HDI 90
AND a 1980 Z1000ST
AND a 1983 GPz1100 inj
AND a 1995 Zephyr 1100
AND a 1980 Z650 (my moped) - x 315
Tool advice
Pete
- My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE - x 2500
Re: Tool advice
This is my set they're marked E10 to E24
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
- moizeau
407 HDI 136 auto
C4 2l petrol coupé
AND a 1980 Z1000ST
Re: Tool advice
Thanks very much Gibbo, what sizes do they relate to in mm please?
Cheers
Cheers
Pete
Re: Tool advice
That will vary according to the bolt type, so trial and error I'm afraid. Some cylinder head bolts for instance may have 10 mm shanks and some 8mm but with the same size torx head.
- (Donor 2021)
- Lexia Available: Yes
- My Cars: Peugeot 206 1.4 HDi 2004
Citroen C1 1.0 2008 - x 10
Re: Tool advice
Hi!
Hope it is of some help. I've always found it useful to know the mm sizes of torx heads. The metric screw stem, as Gibbo said, often varies, since one torx head can accommodate different stem diameters. The most usual ones are listed here too.
Bye
Davide
- moizeau
407 HDI 136 auto
C4 2l petrol coupé
AND a 1980 Z1000ST
Re: Tool advice
Thanks Davide, that's excellent information.
Pete
Re: Tool advice
I have a long cylinder head stretch bolt here, I've just checked against your chart, it has an E14 head but the screw is only 9mm so as I said not always as you would expect.
