DS4 THP200 P000A
metalhead_79
DS4 THP200 P000A
Unread post by metalhead_79 »
Have a 2011 DS4 that has started throwing P000A code.
Any tips where to start looking?
x 6950
Re: DS4 THP200 P000A
It's very likely to be your Camshaft Position Sensor showing a position mismatch.
metalhead_79
So a new sensor for the inlet should do the trick?
x 6950
Well that is the likely suspect with this fault code. - There's a discrepancy with the positioning and what the sensor is reporting - so a good place to start.
Just don't scrimp on a really cheap part, and I would personally advise against buying anything like this from ECP - they are notoriously known for supplying duff parts.
If you need Citroen part numbers / parts diagrams you might want to consider upgrading membership for a £10 Forum donation. That will cover you for up to 2 years of parts requests. Details below:
A response to your question by a Forum Admin will require detailed vehicle information that requires you to have made a current contribution to the Forum.
Donate
Further Information
x 1481
Unread post by xantia_v6 »
Or maybe a new timing chain...
metalhead_79
Hopefully not chain, from what I understand not as usual on the thp 200 engine as others.
The fault is a bit sporadic. Sometimes comes on with repair engine message and you can feel the car going into limp mode with power loss. Next time you start the car the engine fault is still active, but without power loss. The engine light has even gone out on it's own occasionally.
Thought I would take a look at the vanos solenoids as well and give them a clean. The front one (exhaust) is easily accessible, but what is the best way to access the rear one (intake)?
x 1481
I have only done the rear VANOS solenoid on a 156 in a 308, but access is probably similarly bad. I think that I may have undone the intake manifold and pushed it to one side (without disconnecting the wires and hoses).
You cant really see the Torx screw that holds the solenoid, but it is tight and easy to damage. I managed to squeeze an impact driver into the space between the engine and firewall to undo it.
metalhead_79
The fault code seems to be triggered only when the car is cold. Likewise the engine light only goes out spontaneously when the car is up to temp.
Does this point to anything?
Kronfels
Unread post by Kronfels »
Hello, did you fix the issue? Thank you
