Hello from Sweden
Our friends work car started to run on 3 cylinders and was producing a lot of smoke.
Fault code on cylinder 3, missfire.
BUT.
What cylinder is 1?
And Id be very thankfull if someome could tell me what ECU it has and what type of injectors.
VIN:
I have SnapOn and Autocom. Do not have Peugeot specific OBD - only Renault (CanClip).
Thak you!
Boxer MK3 what type injectors?
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Boxer MK3 what type injectors?
Number 1 Cylinder should be at the Flywheel end.
The ECU is typically a Visteon unit, but if you want part PSA part numbers for any of the items, we ask for a small forum donation of £10 that will cover you up to 2 years of part numbers / parts diagrams, as we are are charged by PSA. Details here:
A response to your question by a Forum Admin will require detailed vehicle information that requires you to have made a current contribution to the Forum. |
Donate Further Information |
- Orchid70
- (Donor 2021)
- My Cars: Citroen C5 2011
- x 5
Absolutely!! I always do when there is a possibility to donation.
Thank you!
Thank you!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Thanks for your donation - your member status has been upgraded automatically. Give me a minute or 2 and I'll get some info for you.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok so, for the Injection ECU: Item (1)
Brand New: The original PSA part number was 1943CS, but this was replaced with a newer part: 9666484680, £1603.82
Peugeot also provide an exchange ECU and this is part number: 1677661380, £1603.81
For the Injectors: Item (2)
These are Ford / Denso. New, PSA part number: 1980J7, £552.59
Exchange, part number: 1980T7, £399.61
All the above are from Peugeot and include UK VAT at 20% - so you have an idea of cost.
Anything else, let me know.
