C3 2017, Display screen issue
This section is for General Enquiries or for Systems not Covered Above
Gazzalene
Unread post by Gazzalene »
Several times now my wifes C3 display screen as acted weird. it goes unreadable and freezes.Nothing will clear the screen unless the ignition is turned off,then it goes off after apx 5-10 seconds. on restarting the display is back to normal.
Any ideas of the cause,is this a sign its on its way out? or known issue?
x 6950
Re: C3 2017, Display screen issue
Hi
When you say the screen goes unreadable, what exactly is displayed? Garbled text, blank, lines? This could be important.
Gazzalene
Sorry for late reply.
It is really hard to discribe.Its all horizontal lines .in blocks and of different colours.
No text or words present. like a pc with display card issue.
x 6950
I assume this is the large touchscreen in the middle of the dash. If so, it really needs a diagnostic to determine the issue. It may be the screen or the main unit inside the dash.
These units are not cheap - about £800 for the screen alone and another £920 for the telematic unit in the dash, so best to be sure what the problem is. There are a whole range of different units and screens, depending on options fitted tot he car, so it is essential that the correct one is fitted if a replacement is needed.
Depending on whether you've had it serviced by Citroen from new and the current mileage - they may make a goodwill gesture - but I can't say for sure.
