Can i resolve these via Diagbox?
itachi0125
Unread post by itachi0125 »
Hey guys, i have some crash data on my Peugeot Expert 2018 and the garage i went to couldn't resolve them, if i buy lexia 3 kit would I be able to get somewhere with Diagbox, ive attached some images of the diagnostic report.
Reason: Images rotated.
x 6956
Re: Can i resolve these via Diagbox?
You probably won't get any more explanation wise than what you have above. Diagbox (the software) can undertake live tests and let you see the live data, but won't really tell you much more about the code. Also, for a 2018 model, don't bother with anyone offering Diagbox V7. You'll need a later Version (9.**) to be able to deal with newer ECUs and their software in later vehicles.
itachi0125
Thanks for the reply, would i be able to clear the faults though because it’s been repaired but the faults persist, needs some sort of reset
x 6956
What you need to understand is that if the Diagbox software version is not of a high enough version for the later software and ECUs installed on later vehicles (around 2017/18 onwards), then it won't be able to 'talk' to some of the ECUs or the later BSIs. The Diagbox database won't have the correct ECU data installed - so it would be like a Welshman saying "Glaswellt gwyrdd, gwyrdd y cartref" to a Russian. :-D
itachi0125
Time to buy lexia3 and get started, does EasyDiagnostic by any chance provide Diagbox 9.x with purchases of hardware?
x 3277
According to their website it comes with DiagBox 8.17, but I don't know how long ago they updated the website;
https://www.easydiagnostics.co.uk/produ ... t-vehicles
itachi0125
Incase anyone needs this in the future, heres the reply from Easy Diagnostic:
Lexia 3 kit comes with Diagbox 7.57 and updates to 8.17
If later version Diagbox is needed then we have Diagbox 9.68 VirtualBox available in the shop for £25.
itachi0125
Im not sure about the rules on this forum about posting links but i found a mega link for 9.68, pm if anyone needs it
x 6956
Things you need to be aware of:
The Virtualbox version of DB V9.** requires a laptop with chipset capable of virtualisation and running a VM. You can see if this is supported in your BIOS. Otherwise it won't run and you will need to buy a standalone version of DB 9.** that can't be updated - it's a lifetime licence which is charged for by the sellers.
itachi0125
Would you be able to provide a discount code for EasyDiagnostic by any chance, ive sent a PM, would be really appreciated
x 6956
I've sorted this for you now - check your PMs. :wink:
itachi0125
Got it, thanks! :)
itachi0125
Lexia3 kit order is in!
Anyone got any recommendations for a battery stabiliser?
lorddevereux
x 4
Unread post by lorddevereux »
IIRC crash data can't be cleared with Diagbox, it has to have the unit virginised which is doable but you need a different tool to read/write the flash.
The software is freely available, but sometimes it's worth the money for the expert support provided by some sellers.
x 1044
Unread post by wheeler »
