PC RAM
- x 1056
PC RAM
Can any PC techy type people here identify what type of RAM this is? I know theres a few different types. Its from a Windows 10 desktop. Im looking to get another one to double up the RAM to 8gb.
Tried typing some of the numbers into ebay but nothing helpful comes up.
- x 8054
Re: PC RAM
Search for 'Ramaxel PC4 2400T ram' and you will get many options.
moizeau
- x 429
Re: PC RAM
It's ddr4 type ram running at 2400 mhz, If you got onto Crucial's website you can ask them to scan your PC to find the correct stick.
Pete
- x 1056
Re: PC RAM
Exactly, thats the problemmickthemaverick wrote: 27 Feb 2021, 08:32 Search for 'Ramaxel PC4 2400T ram' and you will get many options.![]()
So its DDR4? Does it have to be 2400 MHz or can you go higher/lower?
Also does RAM have to be in equal pairs or could you have a 4g & a 8g ?
- x 6954
Re: PC RAM
It depends on your PC / motherboard as to what type of memory it supports and what speed it can run at and whether it has to be matched memory or not.
If you pop up your make, model and serial number, I can probably determine what options you have.
- x 8054
Re: PC RAM
In my experience of upgrading I have always used the same. I imagine you could fit higher speed but I would only do that by changing the existing 4gb and fit 2 new faster cards. When I said 'many options' I meant sellers with the right spec ram
- x 1056
- x 2941
Re: PC RAM
I've always used the Crucial site it works well for memory upgrades and SSDs.
https://uk.crucial.com/?cm_mmc=bing-_-u ... b7c77:G:s
- x 6954
Re: PC RAM
You've managed to get the camera flash reflection right over the sub-model which is important - can you tell me what the characters after the ideacentre 510S says?
thorter
- x 41
Re: PC RAM
Yes, I suggest you use the Crucial website, which can identify the appropriate memory for your PC. Further, you get a guarantee from them of compatibility. They are generally price competitive, and quality is excellent.
- x 6954
Re: PC RAM
It's ok I've got it now, here you go. You've got a 510S-08ISH:
https://uk.crucial.com/compatible-upgra ... 510s-08ish
- x 1056
Re: PC RAM
Great, i’ll have a look.
One last thing, is desktop & Laptop RAM still different sizes?
- x 3294
Re: PC RAM
Yes. Typically laptop RAM is about 2/3 the physical size of PC RAM. Try to get as close to identical RAM as that which is already installed. If RAM cards are too dissimilar it can cause issues (the worst being that the computer won't even boot up). However, identical specced RAM cards can improve performance over and above what you might expect. For example, memory interleaving could come into play, seriously increasing the performance of the computer.
- x 1056
Re: PC RAM
Thanks, Depending on prices & availability i may just try to get a single 8gb one.
- x 8054
Re: PC RAM
You could try this option, spec and make is the same, serial number only 5 different so should be perfect!!
https://www.ebay.co.uk/itm/Ramaxel-4GB- ... Sw9iZgITKw
