Which Clutch Kit to choose for 3008
EternalParsley
(Donor 2021)
Unread post by EternalParsley »
Hello Good people,
I was wondering could someone help me out here, clutch in my 2010 Peugeot 3008 died yesterday...
I was quoted that the new clutch kit will cost me 735 euro and an additional 200 for the work.
I spend some time online and I found Clutch kits that are much much cheaper than what shop quoted me. I managed to narrow down my selection to 2x options either:
LuK 600 0297 00 Clutch Kit: https://www.car-parts.ie/car-parts/luk/p-13766317
or
LuK 600 0300 00 Clutch Kit: https://www.car-parts.ie/car-parts/luk/p-14356779
These kits are identical except "Central Slave Cylinder, clutch" is there any way to find out which one I need without actually taking the gearbox apart and looking inside?
Thank you in advance for any help.
x 6945
Re: Which Clutch Kit to choose for 3008
Hi
We can help you out with official live parts data, but we do ask for a £10 Forum contribution as we are now charged for this data by PSA. Details below:
A response to your question by a Forum Admin will require detailed vehicle information that requires you to have made a current contribution to the Forum.
Donate
Further Information
EternalParsley
(Donor 2021)
Donation made what information would you need from me?
Thank you!
Engine Code 9HZ (DV6TED4)
x 1938
You need to post your VIN here. It'll be masked by the forum software so you're secure doing that.
EDIT
Ha ha, you added it to your post in the time it took me to make my post!
x 6945
Ok, so here you go:
You have 2 options from Peugeot:
OEM Peugeot New Kit: Part 2052X5 £374.69
OEM Service Exchange Kit: Part 2051Y8 £200.00
Similarly for the thrust bearing item (3):
New Peugeot OEM Part 204195 £124.67
Cheaper version offered by Peugeot 1666662980 £123.13
All prices UK VAT inclusive as of today.
Don't forget you'll need a centring tool and adaptor to fit it properly.
x 6945
You didn't ask about the Dual Mass Flywheel which it is recommended you do at the same time as the clutch:
Original New: Part 0532Q4 £773.57
Exchange: 1613938480 £450.90
x 5672
What happened to thrust bearings? The last one I bought was eight quid!
EternalParsley
(Donor 2021)
Thank you soo much!!!!
Recording to the information you provided me LuK 600 0297 00 Clutch Kit is what I need.
LuK 510 0129 10 Central Slave Cylinder, clutch - Is an alternative to New Peugeot OEM Part 204195
LuK 623 3241 09 Clutch Kit - Is an alternative to OEM Peugeot New Kit: Part 2052X5
and the
LuK 415 0396 10 Flywheel - Is an alternative to Original New: Part 0532Q4
The whole set will cost 385 euro! That is 300 cheaper than what my local shops quoted me! I'm aware that there are not "original" parts but hey this car is already 11 years old....
x 6945
No worries, good luck.
x 1052
Unread post by wheeler »
myglaren wrote: 15 Feb 2021, 17:50 What happened to thrust bearings? The last one I bought was eight quid!
It will be a concentric type thrust bearing, it has the clutch hydraulics integrated to it.
Genuine PSA clutches used to come with an alignment tool too but now you need to buy it separately.
EternalParsley
(Donor 2021)
Hi, there could you find out the part number for "Master clutch cylinder" ... That was the reason why the whole clutch went.... someone put it the wrong way... I'm having a hard time to find the spare part for it.
x 6945
Item (12), Part: 2182F5, £98.06 Inc. VAT
