What kind of eolys?
Average human
What kind of eolys?
Unread post by Average human »
Hi everyone. Iam new to the forum. I have search ed everywhere but cant find which eolys fluid i should use for my car. I have a peugeot 407 from 2004. The eolys fluid tank CAP is White and My vin nr is VF3**************[VIN obfuscated, can be read by forum staff].
Thanks you!
x 3302
Re: What kind of eolys?
Hi, and :welc: to the forum.
x 6955
Average human wrote: 14 Feb 2021, 10:30 Hi everyone. Iam new to the forum. I have search ed everywhere but cant find which eolys fluid i should use for my car. I have a peugeot 407 from 2004. The eolys fluid tank CAP is White and My vin nr is VF3**************[VIN obfuscated, can be read by forum staff].
Thanks you!
Your build date (RPO) is 10061, but with white click fit connectors confirmed, your original additive would of been DPX42 and this additive can't be mixed with later types, so this is what you need officially.
Average human
GiveMeABreak wrote: 14 Feb 2021, 11:11
Average human wrote: 14 Feb 2021, 10:30 Hi everyone. Iam new to the forum. I have search ed everywhere but cant find which eolys fluid i should use for my car. I have a peugeot 407 from 2004. The eolys fluid tank CAP is White and My vin nr is VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff].
Thanks you!
Thanks alot for the help!
x 1056
Unread post by wheeler »
DPX42 was only used up to around late 2002.
On that RP number it should be Eolys 176 fluid which can have a white or green click fit connection.
If it previously had Infineum F7995 additive you can add Eolys 176 no problem without draining first.
x 6955
I would stick with the official guidance:
Conversion chart for filling or topping-up operations
Additive present in the vehicleColour of clickfit on filler interfaceAdditive to be used in all operations
DPX 42Click-fit neither blue nor greenDPX 42
EOLYS 176Green clickfitINFINEUM F7995
INFINEUM F7995Green clickfitINFINEUM F7995
EOLYS POWERFLEXBlue clickfitEOLYS POWERFLEX
Your vehicle was an early (May 2004) build, so may still of had the old system fitted (using up old stocks), so this clearly states DPX42 if neither Blue nor Green.
x 1056
I think your info may be out of date as it still refers to Infineum F7995 which has now been made obsolete.
This below is official guidance which also states the colour of the click-fit union on the filler interface is not sufficient to determine the recommended additive.
Only the RPO number of the vehicle can precisely determine the recommended additive.
One of my own vehicles has a build date within a few days of the changeover & has contradicting click fit connection colours to what should be on it.
Average human
GiveMeABreak wrote: 14 Feb 2021, 14:13 I would stick with the official guidance:
Should i drain the old fluid first? Or can i just film it up?
x 1056
Average human wrote: 14 Feb 2021, 15:08
If it has previously had Infineum F7995 then Eolys 176 can be added without draining the system first.
x 6955
wheeler wrote: 14 Feb 2021, 15:06 I think your info may be out of date as it still refers to Infineum F7995 which has now been made obsolete.
I have the latest available data from Citroen (Aug 2020 concerning additives) - not the older Peugeot one your are using which I can see is also dated, but the one I have is so new it doesn't even refer to the click fit connectors anymore, so is no good in this case if we are to still be using that system.
It does refer to the build dates and the additive names, but again there is this ongoing conflicting info between using the RPO and the click fit colours. Given that this car is mid 2004, I think it's safe to assume that the guidance up to 2014/15 which I used before is relevant for the year and the car having the white click fits - but yours does state the white or green unions which mine seems the opposite! :-D
If the OP is in any doubt though, it may be better to get it confirmed officially.
The issue is determining if this is a First or Second generation particle filter - if it was a second gen it wouldn't be such an issue:
"Vehicles initially put on the market with a particle filter additive of the second generation are to be refilled with an additive of the third generation. The additive to be used, 95 or EOLYS EXTEND, is specified in the vehicle’s repair procedure."
x 1056
The Peugeot document I’m using was last updated in January 2021, the Citroen equivalent of the same document also has the same date.
Id say this car is way too late to use DPX42, it was only used on the earliest FAP equipped vehicles up to late 2002.
Average human
It seems that i might have to get it to a garage to be 100% sure witch one i need. Thanks for the help guys, i appreciate it slot😊??
x 6955
No problems - it's one of those lovely PSA areas that's as clear as mud, like their wiring diagrams tend to be :-D
I don't think either of us can be 100% certain on this one, so do make your own enquiries for your own piece of mind.
pejcicbozidar
Unread post by pejcicbozidar »
Hi to everyone,
May I ask you for little help, I need eolys type for my car:
C4 Picasso Spacetourer 2017.
3DBHZM/2S
Model Engine: DV6FC(BHZ)
BVM6
ECU: Bosch EDC17C60
Diagbox said: 1.2L of eolys, i supposed it is Powerflex.
Thanx!
Regards,
Bozidar
x 1056
You are correct, its Powerflex on this vehicle.
