x 1751
"It's Quicker by Tube"...
x 2941
NewcastleFalcon wrote: 20 Jan 2021, 14:51 All our yesterdays and those vacuum tubes inspiring all our todays :?:
Maybe he pinched :wink: ...........adapted Brunel's idea http://www.ikbrunel.org.uk/atmospheric-railway
x 8084
Thanks for posting that Gibbo, having read Brunel's theory it is my understanding that the train was "sucked" along by removing the air in front of it causing low pressure and thereby allowing the atmospheric pressure at the back to push it along. Is that how others see it? :)
x 3304
Brunel did do a design where there was a 'slug' that went into a tube and then was vacuum pulled, pulling the Atmospheric Train with it. The problem was the seal (the tube had a slot out of the top where the 'arm' went onto the 'slug'). Brunel used oiled leather, which had to be properly maintained, and rats would eat the leather.
https://en.wikipedia.org/wiki/Atmospheric_railway
x 1240
Unread post by Peter.N. »
I think that was down here somewhere near the Saltash bridge.
x 8350
Hell Razor5543 wrote: 21 Jan 2021, 11:48 Brunel did do a design where there was a 'slug' that went into a tube and then was vacuum pulled, pulling the Atmospheric Train with it. The problem was the seal (the tube had a slot out of the top where the 'arm' went onto the 'slug'). Brunel used oiled leather, which had to be properly maintained, and rats would eat the leather.
He was way ahead of his time with this... Today and with modern materials and techniques I'd think it could be made to work effectively...
It would surely look a lot neater than the standard 25Kv OHLE 'knitting' that spoils the look of what otherwise would be some very scenic railways... And who knows, cheaper too maybe...
x 3304
CitroJim wrote: 21 Jan 2021, 17:44
The biggest problem would still be keeping the pipework sealed. Yes, technology (in all of the related areas) has moved on, but so has human nature (or, rather, stupidity). I can see idiots damaging the pipework, or wedging open the seals (if they can), or dropping things in to go hurtling to the vacuum engine and damage it.
I recall seeing (on BBC Click) a Magnetic/Atmospheric railway (reduced scale model) where a very powerful magnetic 'slug' was travelling along a sealed (non-magnetic) pipe sited in a rail line, towing a train (which had a partner magnet on an arm close to the pipe. This train travelled up and down slopes and round bends. While the model worked well there would have to be a way of monitoring the magnetic 'grapple' so that, should the magnets let go of each other, the 'slug' does not go hammering along the pipe as high speed, possibly causing damage at the terminus end, while a following train does not plough into the back of a stationary train.
x 8350
Hell Razor5543 wrote: 21 Jan 2021, 17:54
You make a very valid point there James... :(
x 2941
Remember "Go suck a Zube." :) It just came out in a conversation I was having with an old friend.
x 8084
Indeed I do Gibbo, and a fine source of handy little tins they were too!! :-D
x 7164
No don't remember them, but here's an ad
x 8084
A few weeks ago I posted this on this thread
so imagine my delight when I came across this today: :-D
https://www.the-saleroom.com/en-gb/auct ... b500ba537c
x 7164
Peter.N. wrote: 16 Oct 2020, 23:43 I came across this card recently, it's where I used to work in the '50s.
I came across this in 2021, February 22nd to be precise.
This traditional, and long established TV and Radio Sales and Service Shop, now has a "Vaping wing".......odd and just a touch disappointing!
x 7164
Just watching the Big Match revisited Aston Villa v Stoke in the First Division of the English Football League.
How refreshing to see a dog on the pitch making it through to the highlights.
I'm afraid the Premier League and all its riches never provides such simple entertainment. :-D
x 7164
You can't beat a bit of British Pathe
1967 ish the electric Car revolution was about to start and Britain was way ahead of the world. :-D Even Issigonis was hard at work at Longbridge on the project. Doesn't last long, fascinating
