C4 Picasso 2015 (B78 plate) Heating problems
Molsonwill
(Donor 2021)
x 3
Re: C4 Picasso 2015 (B78 plate) Heating problems
Unread post by Molsonwill »
That in itself is nice to see.
x 6945
Well spotted there Richard!
Danieldan
Unread post by Danieldan »
Molsonwill wrote: 09 Jan 2021, 17:53 Image
hi marc, this is a link to an image of the heater box and the hole i was talking about emitting cold air. i'd just like to understand what this is before dismantling further . vin number is VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
there is nothing to go on it and the floor heater duct is above. there is no matching hole on the n/s.
I don't know if this is the correct way to post an image. Will.
There is a small hose from your glove compartment box that will fit onto that hole, you can duct it and close the lid inside the glove compartment box! :)
x 5672
Glovebox chiller :)
Molsonwill
(Donor 2021)
x 3
glovebox chiller! thats exellent . Just like to say big thanks to everyone for your help and share with you my heater matrix cleaning method. Overnight soak in vinegar and strap to a 25 ton piece of quarry equipment for one hour. Heater sorted, thanks again. Will.
x 6945
That's hilarious! :rofl2:
EDC5
x 130
Unread post by EDC5 »
Haha, very good!
x 5672
I said stirred and not shaken! :twisted:
That should get the crap out of it!
x 1490
Love it, that's got to be candidate for post of the year in week 2!!
Molsonwill
(Donor 2021)
x 3
If I could just trouble you with another roughly related issue, i recently fitted a new thermostat housing whilst working on the heater. afterwards i was checking the air con [which i'd just repaired] and found it failing. whilst trying to determain the gas situation i foolishly bridged the contacts on the pressure sensor plug. ever sincse it is showing maf sensor faults, both low and high flow. the fault appears straight away after clearing the codes and starting the engine. I've tried replacing the sensor , first a cheap one and then not a cheap one with no result. worried that i may have damaged ecu. i've checked all the fuses. My next step was going to be if there is any power going to the maf plug.
Molsonwill
(Donor 2021)
x 3
Mexico14
Unread post by Mexico14 »
Image sorry to hijack the thread but could someone confirm if this is the pipe to the heating matrix? It's the drivers side and feels cold. Symptoms are no heating on drivers side (RHD).
https://ibb.co/nLqsYVY
Molsonwill
(Donor 2021)
x 3
can't tell from that picture but its odds on matrix blocked. it's not difficult to get out ( access interior n/s) When out put hot water in and see where its hot.
Mexico14
Is the matrix usually covered by warranty? I've been on to the dealer and they reckon citroen may not cover a matrix as they don't usually do radiator parts that have been effected by corrosion?
Is the "sludge" that seems to be causing the problems actually considered corrosion? Give the fact the matrix part has changed slightly - isn't that grounds that they should cover it under warranty as its a defective design?
mnsdall
Unread post by mnsdall »
GiveMeABreak wrote: 23 Dec 2019, 12:26 Hi Janko
You'll probably find that this is down to the air mixing flap motors. Depending on system fitted, there will be both air distribution and air mixing flaps. Sometimes the plastic cogs or the spindles wear out. So the motor turns the spindle to adjust the flaps, but where the plastic is worn, it just turns and can't move the flap - so the air mixing remains at the same setting (when engine warms up of course).
If you post your VIN up I can check the system you have fitted.
Can you Please let me know." plastic cogs or the spindles " can be replaced, if yes the part no will be very helpful, as my garage said I should replace the whole unit and they have quoted me £1800 for that replacement :(
