On your Bike
x 8417
Re: On your Bike
Timmo wrote: 05 Jan 2021, 21:06 I've an eccentric lady I'm the village that covered an old steel Raleigh step through with a Chinese ebike kit! Hub motor so powerful it stretched out the fork drop outs! Things bloomin Lethal!
:lol: A member of the local chapter of the 'Hell's Grannies' by any chance? :twisted:
Ironically, I saw this when out for my run today... These NCN route markers were erected to celebrate the Millennium and this one has recently been refurbished :D There are a number in MK and I've seen them on other NCN routes well beyond Milton Keynes...
NCN6 Route Marker, MK Railway Walk
It looks good, by headtorch-light at least :)
Timmo
(Donor 2022)
x 168
Re: On your Bike
Unread post by Timmo »
That's rather nice Jim! All we have are the route stickers on sign posts! 😀
'58 C2 Code
'58 partner teepee outdoor
old'uns
x 127
Re: On your Bike
Unread post by old'uns »
well the tyres stayed up and back brake no longer dragging :)
still squealing away though, disc rubbed and cleaned with cleaners, new pads and bedded in gently.
sure i read somewhere it could be vibration rather than pad/disc? and the cure may be to put some cable ties around the rotor vanes?
first ride of the year in the Ice, Snow, Mud, slush etc...more nervous than physical energy burned i think :-D
Timmo
(Donor 2022)
x 168
Re: On your Bike
Squeeling brakes could be a few options, glazed pads is the first port of call, shiny disc surface, mis alignment of the caliper causing the disc to be pushed to the opposite pad is a common one, doesn't take much,
Bedding in process I use is one of the hills in the village, minimal use of brake to said hill, then roll into it, is long enough and steep enough to allow me 4 to 5 good hard pulls on the brake to almost stopped from 20+mph, they need a little heat in them to clear out any residue,
I thought I best add a little context to my answers here, so a couple of images of my cycle repair workshop! This is V3, V1 was the original outhouse shed, 14x8ish, after 7 years it became a little small, replaced it with a Yardmaster Garage in 18x10! Just on the year anniversary of the new shed, the stereo amp over heated causing a fire early one Sunday morning in June, lost the lot, 2 bike frames survived by being Steel, all the alloy bikes Melted, so this is V3, the rebuilt, tweaked design shed!
Today's 2 jobs pretty much opposite ends of the spectrum!
'58 C2 Code
x 8417
Re: On your Bike
That's a lovely workshop Timmo :D
So sad you lost it all with a fire :( But good to see you're truly back in business again!
Timmo
(Donor 2022)
x 168
Re: On your Bike
A bloomin fresh one out this morning! Loop out around the beacon in St Agness, lots of climbing! But a beautiful day to be out!
https://www.relive.cc/view/vXOnM7Gm55v
Little video of the route! 😉😉
Still struggling with the cold toes mind, temperature certainly didn't help today!
'58 C2 Code
x 8417
Re: On your Bike
That looks a lovely spot Timmo :)
Compared to recent days, it's been quite balmy up this way :) Hence why I cracked on with Daffodil today...
And today was the first morning in a while I've been able to run without getting very cold hands... You suffer with toes and I suffer with my hands in the cold :twisted:
Is that a Trig. Pillar in the picture?
Timmo
(Donor 2022)
x 168
Re: On your Bike
yes indeed jim, is known as St.Agness beacon, would have been an old navigation/trig point, is also one up on Carn marth on the other side of Redruth, there is a little bit about it on a bird watching page here https://cornishbirdblog.com/2019/06/01/st-agnes-beacon/
you can see up to padstow on a clear day and down to st.ives, cant quite see the other coast as its not quite high enough, one of my favorite views is down on the coast path looking over Wheal francis and down the coast to Godrevy, all the troubles fade away sat there!! (another image on the link of the engine house views)
'58 C2 Code
x 8417
Re: On your Bike
Thanks Timmo :D Oh to be in such a magical place! You are very fortunate indeed ;)
x 2938
Re: On your Bike
What do you think of all the newspaper condemnation of Boris for his seven mile ride Jim? :-D
x 8417
Re: On your Bike
Gibbo2286 wrote: 12 Jan 2021, 09:58 What do you think of all the newspaper condemnation of Boris for his seven mile ride Jim? :-D
I've given it no thought and don't intend to Eric ;)
Skull
(Donor 2026)
x 382
Re: On your Bike
Unread post by Skull »
First crash of the season today :(
One large sheet of ice in an hours ride, luckily it was low speed as I had just gone through a flooded section, everywhere else was well into the thaw so caught me totally by surprise. Sometimes you can get away with a small patch of ice but the fact I was still on the ice when I came to a stop and almost fell back over when I got to my feet, tells me it wasn't savable #-o
Hip took the brunt of it so might try to get some padded foam sewn in but hopefully wont happen again .....as the Sergeant on Hill Street Blues used to say 'be careful out there ......'
Gary
x 8417
Re: On your Bike
Oh ouch Skull :(
Hope no harm done an the hip is soon good again 👍
Timmo
(Donor 2022)
x 168
Re: On your Bike
hope you guys are all good, no longing effects from the ice off skull??
Beautiful day down here yesterday, snuck 4 runs down the local 'mountain' , - its not a mountain really but as close as we get!! :-D Lots and Lots of walkers about, good few other cyclists too! hope you all managed to get out to some degree!
'58 C2 Code
Skull
(Donor 2026)
x 382
Re: On your Bike
Cheers Timmo
Nothing major just bruised knee and hip - been out today for a 40 minute stretch ....
Gary
