Could I possibly DIY 🤔 all brake pads on my C5?
- My Cars: Citroën C5 Exclusive 2008
Re: Could I possibly DIY 🤔 all brake pads on my C5?
Jack's arriving today. I'm going to get those lambda sensors out today! I was examining the top one last night & found it clipped at multiple places, not sure where the connector ends but will see. A few pics below;
Re: Lambda Sensors on C5
Lambda Sensor won't come out! Not a flinch! Grrrr . I even tried to disconnect it first but still wouldn't disconnect from the female chassis. I'll try again this weekend.
It is anticlockwise isn't it?
I doubt it's ever been changed.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Try tightening it slightly first. If there is rust on the threads trying to undo the sensor will just cause the rust to act like a wedge and bind. Tightening it first can cause the rust to fall away, so it then does not wedge.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Lovely. Thanks . I'll try that!
Top sensor done. Bottom one erm ...hopefully today. I'll try the pads this weekend too. Been so busy with work.
Audio upgrade coming up too. I'm looking at changing the dash to fit a proper touch screen from China with new speakers. I found some on ebay but audio unit definitely China.
Transmission Oil Pressure Switch...I think that's beyond my wit.
Oh forgot to mention I'm fat! hehehe...
What to do?
- My Cars: Citroen C5 X7 tourer 2009
If you cannot get the car any higher, get help would be my suggestion. Also do not use the socket here as there is, as said very little space, just get the right size wrench in there and then it will be 'easy'.
Any luck with the brakes?
Hi Rrijken,
Oh thanks for the tip. A wrench definitely .
I'll do the brakes this weekend hopefully!
I got this few minutes ago. What does it mean?
It's a new sensor.
It's a new sensor.
Is the sensor a cheap one from China?
Did you do:
connect lexia PC to car and reset all auto adaptives
Did you do:
Sensors all OK. Did some terminal tests with my multimeter. Rectified issues. Passed MOT flawlessly hurrah!
°°°°irrelevant info - all ridex parts°°°°
Can't wait to upgrade the audio, just awaiting delivery. Pioneer speakers delivered. New dash delivered. I'm bent towards insulating the car some more ...
Brakes done effortlessly didn't even break a sweat!
I found this today underneath RH Passenger seat and not sure what it is.
OnlinePaul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1379
If you mean the RH rear seat then it's the cover over the TSU (tank sender unit). It's in the same place on virtually all PSA cars. The TSU can also incorporate an in-tank fuel pump if that particular engine needs one.
