First two weeks with the Xantia
admiral51
(Donor 2026)
x 391
Re: First two weeks with the Xantia
Unread post by admiral51 »
Have been reading back on OP posts.
So a couple of questions.
#1 to OP #2 to everyone
1. Can you use the radio with key out of the ignition, ie press the on button and radio should work ( should work with aftermarket head unit ?)
2. If the OP can find the correct wire and splice like i did then until the Bodge wiring is removed nothing will change or just cause problems in fault finding ?
Colin
x 8401
admiral51 wrote: 01 Nov 2020, 14:57 Good to see you Clogzz, my go to person from when i first joined the forum for all things A/C +fans :)
Seconded :D How are you keeping these day Clogzz? Well I trust...
Michel
Unread post by Michel »
Warm up? The HDis I’ve had take ages to warm up, a good 5 or 6 miles in the cold weather and that’s with me “leaning on it” a bit on my back roads commute.
thatfatbloke69
Unread post by thatfatbloke69 »
admiral51 wrote: 01 Nov 2020, 16:06
Colin
#1. No I can't.
Clogzz
x 40
Unread post by Clogzz »
Hello Colin and Jim.
How wonderful to see how well you have recovered.
All well here, I look at the forum about twice per week but haven’t contributed much over the recent years because I only know about the Xantia and C5 Mk I.
The 2002 C5 with AL4 is still making beautiful downshifts. :)
I’ll cobble my time-making machine so as to be able to post more often.
Best wishes.
Terry.
x 8401
Terry, thanks and great to hear you and your C5 are keeping very well :D
Don't be a stranger ;) The FCF remains a brilliant place to be :cool:
x 1746
There should be two +12 supplies to the radio
1 - via IGN switch (radio only works with IGN on, usually in Acc position)
2 - permanent +12 live (allows radio to be turned on even when IGN isn't; also keeps radio memory alive)
and
3 - +12 "lights on" (usually from panel lights, maybe sidelight circuit; when live, dims the radio display)
4 - Gnd
plus Antenna and Speaker connections
admiral51
(Donor 2026)
x 391
Unfortunately there are some pics and links missing but This Thread will give you some idea on which wires do what on the ignition switch
thatfatbloke69
Thanks for all the replies. Unfortunately the car is up for sale now nice and cheap as my wife doesn't like it and I don't have the time to get these issues sorted.
