Hi i am new here. so hello to everyone. I own C5 X7 2008 and i decide to upgrade stereo from rd4 to rneg2. i bought second hand unit from crushed yumpi. And i installed it in my car. ( i bought facia separatly). Everything works just fine. only problem with instal was a brown power cable for screen. But i manufacture it my self using some old pc cables. Now i have music, usb, navigation, even
fuell consumption info. works. Only one problem when i am conected to bluetoth my mic dont work, it was working perfectly wit my rd4 radio. Do i need some facra conector modification maybe. Thanks in advance. best regards.
Upgrade from RD4 to RNEG2
Moderator: GiveMeABreak
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5646
Re: Upgrade from RD4 to RNEG2
The problem was because with your old RD4 unit, the microphone connected to a separate hands-free box and not to the RD4. Now you are not using this, the microphone needs to be connected directly to the new head unit.
- My Cars: Citroen c5 x7 (2009)
Citroen c5 Mk1 (2001)
Renault Fluence (2012)
Do i need new mic. or i can use old one yust connect it to other place?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
The Mic is wired in such a way that it disappears into the loom, so you will not be able to find the exit point without getting inside the dash to locate the Nomad hands free unit and identify it from there.
Others have bought a new mix and wired it directly to the mic wiring block that is in one of the blocks in the quadlock
Now you get me an idea. i will cut mic wire close to mic. so i don't need to unloop the wires. and i will solder a new wire direct to fakra connector.
it is no problem to buy s new one but this works perfectly.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes, that's another way, before it transforms into the ribbon.
Ok i solved the microphone problem like i said, by cutting wires neer microphone on the connector to ribbon cable, it is working like charm. But now i have another problem, my gps is not working it is constantly "location bad" "visible satellites 0". Is there something i have to change in lexia because i only put the new VIN with lexia, everything else was working normally, so i didn't touch anything.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
When you upgraded, did you ensure you have a proper GPS aerial installed? The RD4 aerial unit is not for GPS reception, it needs a proper aerial for that to work.
Ofcourse. i pulled aerial from yumpi and disassembled it took only the gps module and hot glued it to the glass behind interior light and mic trim. So aerial should not be the problem. What else to look for?
