Peugeot 5008 2.0hdi P11AA P0234 strange turbo noise
itzpeti
Re: Peugeot 5008 2.0hdi P11AA P0234 strange turbo noise
Unread post by itzpeti »
Hey, the strange noise its fixed in turbo? Like in your video. I have this sound also, and want to fix..
itzpeti
Citroen 2.0HDi Strange turbo noise
Hello all!
I have a problem that has been visible here once, viewtopic.php?p=614896#p614896
Strange turbo noise between 0:25 - 0:27 "deep growl":
I experience the same in my DS5 2.0 (same engine) and haven't found the issue yet.
Anyone here experienced the same and got a fix for that?
x 6955
Have you read through this topic? Get the fault codes read with Diagbox and if you are getting the same codes then a replacement of the parts discussed in this topic may be your solution.
itzpeti
GiveMeABreak wrote: 10 Aug 2020, 11:15 Have you read through this topic? Get the fault codes read with Diagbox and if you are getting the same codes then a replacement of the parts discussed in this topic may be your solution.
Problem is, I don't get any error code. But have the same sound like in the video at 0:25-0:27 that "deep growl".
edit: or this error comes without "Engine light" pop up?
x 6955
You won't always have an engine management light pop up on the dash. That is only triggered for certain fault codes.
You need to have it diagnostically checked with Diagbox - generic fault code readers are not always able to read all the fault codes - especially the constructor-specific fault codes that are reserved. Most can only read basic OBDII codes.
itzpeti
GiveMeABreak wrote: 10 Aug 2020, 12:00 You won't always have an engine management light pop up on the dash. That is only triggered for certain fault codes.
Good to know, thank you! I give it a try.
Gregor
x 16
Unread post by Gregor »
Hi. I had similar problems on my C5 for a long time. Garage checked EGR, changed solenoids and some sensors but no change.... P11AA back every few days for the last 20.000 km and black smoke sometimes lots of it when pushed hard. 🤕 Also consumption of diesel rised for cca 1l/100km
I had enough and did some research on my own and bingo! Problem with air leak when under pressure from turbo. Leakage was wery small but big enough to see some black oil sludge between air doser and manifold connection. If thick oil can come out how could than hold pressurised air... I solved this leak with putting some thin epdm rubber ring under the green square profile ring seal to push it out for 0.5 mm and now runs fine again. Also consumption felt down to normal.
Driving Citroen is a diagnose!
itzpeti
Gregor wrote: 06 Jan 2021, 18:00 Hi. I had similar problems on my C5 for a long time. Garage checked EGR, changed solenoids and some sensors but no change.... P11AA back every few days for the last 20.000 km and black smoke sometimes lots of it when pushed hard. 🤕 Also consumption of diesel rised for cca 1l/100km
You also had that weird noise? And problems with slow speed?
Also can you make a photo what you fixed? The part 😊
Gregor
x 16
Such sound is still present, though not so obvious any more.
Green seal ring
Green seal ring
itzpeti
Gregor wrote: 07 Jan 2021, 09:47 Such sound is still present, though not so obvious any more.
Thank you, will check this on my DS5... Im pretty sure I have air problems.. car drives different each day..
Gregor
x 16
When you will take off that air dosier clean pressure sensor niple and temperature prrobe in it and chech if flap inside is moving ok. There will probably be a lot of sot inside housing. I suspect that that part of that strange sound is comming from this part also. Do your DS smoke black when pressed hard?
itzpeti
Gregor
x 16
Manual or auto gearbox? If auto it could be related to it. PSA old auto gearboxes are sort on the lazy side. 😄
Gregor
x 16
Anyway if no black smoke I suppose you are not loosing air on presurized side of air hoses.
x 6955
Also see my post here:
viewtopic.php?p=630598#p630598
