Flashing mileage with no Bluetooth
This section is for General Enquiries or for Systems not Covered Above
Lharl86
Unread post by Lharl86 »
Hi all
I’m hoping someone can help out
I have a Citroen Nemo 2014 plate and suddenly my Bluetooth and usb point do not work and the mileage on the dash is flashing
Any ideas what I need to do?
Lee
x 6956
Re: Flashing mileage with no Bluetooth
Hi and welcome.
Basically, have your wallet ready.
This is a known issue on these vehicles - they are essentially a Fiat design and use Fiat telematics units. The hands free module has known issues - specifically a fault caused by lack of communication with the telematics module. You will probably have Fault codes B10AA and U1733 stored in the BSI and the tell-tale flashing mileage indicator.
A BSI reset (BSI Reset / Battery Disconnect / Reconnect Procedure) may help, but if this fails to correct it then the only solution is a replacement of the handsfree module. They know about this problem and it is documented in a Technical Services Bulletin.
Unfortunately these cost anything from £380-£500 to do.
Lharl86
Ok so what is a bsi reset?
x 6956
Click the red link in my post.
Lharl86
Just tried this but no luck
x 6956
It's not a guaranteed fix, but can eliminate any ECU issues on the vehicle networks.
The same problem exists on some of the larger commercial vehicles like the Relay - with FIAT telematics units. They're useless to be honest. So you'll have to get a new unit and get it fitted and coded or do without it - but the mileage flashing issue will be annoying.
Lharl86
I might contact Citroen
x 6956
When you do, tell them you are aware of a Technical Service Bulletin for this issue and quote the TSB reference:
d5bw010nq0
Those are number zeros, not letter Os.
Lharl86
What does this mean?
Sorry for the questions
x 6956
That is the Citroen dealer technical bulletin that concerns this problem that they are aware of.
If they were to run a diagnostic on the car and if the following 2 fault codes (B10AA and U1733) are logged in the BSI, along with the flashing odometer, then it means the hands free kit is knackered and not communicating. The technical bulletin may advise a "proxy alignment" and failing that, replacement of the unit. I think a Proxy alignment is FIAT speak for some reset or test of the unit.
Waffleman
Unread post by Waffleman »
Hi Lee
Did you go to Citroën about this and what did they say? Did you get it sorted? I have exactly the same issue with my Nemo.
Cheers
Mark
x 6956
The issue is as in my post - it is a known fault with the Bluetooth units and more than likely will need replacing.
Waffleman
Hi Marc
Do you know, does the part in question look like the attached?
Mark
x 6956
The telephone interface module does look similar to that - but it must be the correct part number to be compatible (hardware / software) and may need configuring with a suitable diagnostic tool (like Diagbox with an S1279 interface) if you are thinking of replacing it yourself - but I can't confirm this.
Waffleman
Okay thank you for that info.
