suspension ecu
KennyW
- x 165
Re: suspension ecu
Marc,
It's not picking any ECU's but I think it maybe my laptop as I have tried it with the C3 and no dialogue.
I'm going to completely clean it and reinstall everything.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 6945
Re: suspension ecu
Ok, so this has to be one of 2 things that I can see Kenny:
1) The software has been deactivated.
2) The VCI hardware / Wiring / Pin / Connectors on the Board / Plug
As for point 1) - I've seen this happen a million times - even going into a setting or parameter where it asks for a technician log in and even if you cancel it, deactivation is highly likely. Copying your licence file back resolves this.
Remember, you will not only need to uninstall the software, but the registry needs cleaning and all the relevant folders need manually removing too as reinstalling it without doing all this will not fix the issue. I'll send you a PM on this.
OnlinePaul-R
- x 1940
Re: suspension ecu
Have you thought about putting this information in an FAQ sticky or in the Wiki, Marc?GiveMeABreak wrote: 27 Jul 2020, 10:28... you will not only need to uninstall the software, but the registry needs cleaning and all the relevant folders need manually removing too as reinstalling it without doing all this will not fix the issue. I'll send you a PM on this.
It would save having to collect the info together each time the question is asked and may even save somebody posting a query in the first place.
KennyW
- x 165
Re: suspension ecu
Unfortunately, I have already started the complete clean when I saw your PM.GiveMeABreak wrote: 27 Jul 2020, 10:28 Ok, so this has to be one of 2 things that I can see Kenny:
During my last install I saw briefly a copying error for temp files, possibly and issue with Java, but 7.01 installed successfully but 7.02 requires a reboot to install successfully.
In Windows 7 pro 32bit is there Java already present or requires and upgrade to Java RE 7 or above which cannot be obtained easily.
Kenny
- x 6945
Re: suspension ecu
I would ignore Java - Diagbox installs it anyway and uses the older engine for DB7 Kenny.
@Paul: Yes, I think it's worth investing some time into putting together an 'issues' guide. I'm halfway through it now and will put a link up when I've completed it. Sanity needs to prevail (not aimed at you Kenny!)
KennyW
- x 165
Re: suspension ecu
Thanks Marc, my sanity is prevailing a little longer.
Any suggestions to where I could purchase a new interface ?
Kenny
Kenny
- x 6945
Re: suspension ecu
I've only ever used Jim at ED for mine Kenny, and it's as good today as it's ever been - now that sounds like an advert for Hovis
KennyW
- x 165
Re: suspension ecu
Okay Marc,
Will let you know what happens.
Kenny
Kenny
KennyW
- x 165
Re: suspension ecu
Laptop now completed with new Windows 7 pro 32 bit and updated.
Diagbox installed to 7.57.
Will wait until later to try it out, everything crossed.
Kenny
Kenny
- x 6945
Re: suspension ecu
And licence file backed up.....
KennyW
- x 165
Re: suspension ecu
Yes, licence file back up and copied.
Well it's still not playing ball. It will recognise the VIN but the green light will not stay on solid green in order to carry out global test. It even gives the ignition warning.
Check ignition is on, etc and no dialogue with any ECU's.
I will speak to Jim @Easy Diagnostics probably Tuesday.
Will reply if there is positive news.
Kenny
Kenny
- x 6945
Re: suspension ecu
Sorry to hear that Kenny. AS you can imagine it is hard to see what the issue could be remotely. Let us know what Jim says.
KennyW
- x 165
Re: suspension ecu
Marc,
Sorry I was not clear on my previous post. The green light on the interface flashes when connecting to the laptop and then stays solid green.
It is the green active light on Diagbox does not stay solid green when running it switches off and on. This, I believe, is the problem.
I will check again with the wife's C3. But I suspect the same problem will occur, which makes me suspect the interface is not working correctly.
Kenny
Kenny
- x 1466
Re: suspension ecu
I have been told (but don't remember all of the details) that it is possible to kill the VCI by selecting the wrong model car while it is connected to a car, I was given a failed VCI which was said to have suffered this fate, but I never got around to investigating the internals.
KennyW
- x 165
Re: suspension ecu
Okay, that's interesting.
Will be speaking to Jim tomorrow.
Let us see what happens.
But I have found somebody who says they can repair the interface. Just in case.
Kenny
Kenny
