Gearbox faulty
Mhamilton
Re: Gearbox faulty
Thought that might be the case but hoped it was something that could be worked around
- x 6956
Re: Gearbox faulty
I wouldn't want to say to you replace this and replace that - because I know that these faults can be because of a comms issue in the wiring or another component and that can mount up along with the programming if you don'ty have a kit and someone who knows how to do it. In some cases, it is better to say to the dealer - look I have this fault and that fault and get a prognosis.
Mhamilton
Re: Gearbox faulty
Do you know the part number of the sensor please I’ve taken it off and I’m hoping to get a replacement if it’s not to bad price wise
- x 6956
Re: Gearbox faulty
I can get you the live parts data, but as PSA charge us now, we do ask members for a min £10 Forum donation that will cover you for up to 2 years of live parts data and parts diagrams. If this will help, just follow the link in the table and your status will automatically be updated:
| A response to your question by a forum admin will require detailed vehicle information that requires you to have made a current contribution to the Forum. |
| Donate Further Information |
Mhamilton
Re: Gearbox faulty
Many thank I bit the bullet and got it to a specialist who said sounds like clutch
Any ideas of cost ?
Any ideas of cost ?
Mhamilton
Re: Gearbox faulty
I will be doing the donation in a bit when I get back from garage
- x 6956
Re: Gearbox faulty
The clutches can be a bit expensive to do - but I would expect you to be getting some slippage well before this to be honest - just like a manual, as it has a bog standard clutch, dual mass flywheel and manual gearbox - just with the hydraulic actuators. So any slippage would be a giveaway if the clutch and / or flywheel, so a bit dubious about that - unless he has reason to suspect something else - but I can't see what on the face of it.
They can be a bit fiddly to do as they have to be grid set when changed. I can get you prices when you get back and can post VIN with the necessaries.
Mhamilton
Re: Gearbox faulty
No problem thank you I’ve not noticed any slippage did have a bit of clutch judder but did reset and that went away
- x 6956
Re: Gearbox faulty
Ok, so if you are certain it's the clutch, be prepared to get the DMF done too - as I'm sure you know, the labour is a killer on these, and a DMF will rarely see another clutch out. That may also cure some judder. Time to start melting down the family silver!
- x 6956
Re: Gearbox faulty
Of course, yes Petrol, so Solid Flywheel!
Mhamilton
Re: Gearbox faulty
Makes it a bit better to do
They going to do a full diagnostic check tomorrow With lexia and then check sensors are working as should first as well as check wiring loom so touch wood it’s a straight forwards job rather than box out clutch change
- x 6956
Re: Gearbox faulty
That's what I would of hoped they would start with to be honest. Let us know how it goes.
Mhamilton
Re: Gearbox faulty
The garage have looked at the car via lexia and it won’t fully talk to them
They can ascertain that the gear selector is working but it won’t pressurise the hydraulic system at all the sensors have been removed and are measuring within range
They will be checking through wiring looms Monday
