C5 Cruise Control - new developments
x 1049
Unread post by wheeler »
6239LO was until RP no 9946 but this part no now supersedes onto 6239NK anyway.
406 V6
Unread post by 406 V6 »
"I feel like taking all my clothes off, dancing to the Rite of Spring..."
THANK YOU SO MUCH GUYS!!!!!! [:D][:D][:D][:D][:D]
It's working beautifully!
A pint at the pub next door for all!
x 1049
so was it the RVV configuration ?
Homer
x 16
Unread post by Homer »
Citroen dealers 0 - Andyspares Forum 1
406 V6
You bet wheeler, thanks!
Homer, right as always[:D]
Nobody can beat this forum! EVER!
allmond
Unread post by allmond »
Francisco
Back to a question I've posted before, "What is the lowest speed it goes down to?"
Jamie
bencowell
Unread post by bencowell »
My C5 2.0 HDI 110 (July 2002 build) had CC added afterwards, CC only works in 4th or 5th, and at 25mph or above.
However, if you last had used CC and cancelled it using the brake or clutch, you can press the resume button (just one click of up or down speed button) and it will resume even if you are doing below 25!
Hope this helps
406 V6
I've managed to run at 50Kms/h, and, as Ben says, it only works on 4th and 5th gear.
According to the manual, it should work as low as 40kms/h.
Cheers!
Homer
x 16
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by allmond</i>
Francisco
That might depend on the engine/gearbox.
My 807 manual says 25 or 37 mph depending on engine but doesn't bother to say which engine should be able to be set to which speed.
bencowell
The speed difference will probably be due to CC requiring a minimum number of revs and minimum speed to engage.
I guess the petrol engine will start at the lower speed as the gearing is lower on petrols.
Homer
x 16
Good point.
It does have to be in 4th or 5th (manual).
Kowalski
Unread post by Kowalski »
Cruise control minimum speeds have been discussed before.
The conclusion that I remember was that the minimum speeds hadn't been converted from Km/h to mph, the number was the same just it said mph next to it instead of Km/h (or vice versa).
ausy
Re: C5 Cruise Control - new developments
Unread post by ausy »
It would be fantastic if someone can supply the installation instructions for Cruise Control Kit OEM: 9452.43 [/ B] (quite similar to Waeco MS-700).
I have installed all parts in my Xantia, but still did not connect ECU with servo motor because I don't have original plug that goes to the servomotor, and I can only guess because the wire color is not the same
as with MS-700.
https://ausy.biz/tempomat/box.jpg
https://ausy.biz/tempomat/content.jpg
I looked in the German Citroen forum and asked a few Citroen dealers in Germany, but no success.
I hope that this set has been produced more than once and that someone has incorporated it into Xantia.
Thanks in advance.
cheers
when it comes to fighting the excesses of
capitalism, nothing beats reverse-engineering.
x 3281
Give citroenxm a PM (he is a member on this forum). He has managed to get Cruise Control working on a Xantia HDI (although he had the advantage that the ECU already had the relevant coding in the ECU software, so all he had to do was to connect up the right hardware for it to work).
