C5 Cruise Control - new developments
- x 1050
406 V6
406 V6
allmond
bencowell
My C5 2.0 HDI 110 (July 2002 build) had CC added afterwards, CC only works in 4th or 5th, and at 25mph or above.
However, if you last had used CC and cancelled it using the brake or clutch, you can press the resume button (just one click of up or down speed button) and it will resume even if you are doing below 25!
Hope this helps
Hope this helps
406 V6
Homer
- x 16
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by allmond</i>
Francisco
Back to a question I've posted before, "What is the lowest speed it goes down to?"
That might depend on the engine/gearbox.
My 807 manual says 25 or 37 mph depending on engine but doesn't bother to say which engine should be able to be set to which speed.
Francisco
bencowell
Homer
- x 16
Kowalski
ausy
Re: C5 Cruise Control - new developments
It would be fantastic if someone can supply the installation instructions for Cruise Control Kit OEM: 9452.43 [/ B] (quite similar to Waeco MS-700).
I have installed all parts in my Xantia, but still did not connect ECU with servo motor because I don't have original plug that goes to the servomotor, and I can only guess because the wire color is not the same
as with MS-700.
https://ausy.biz/tempomat/box.jpg
https://ausy.biz/tempomat/content.jpg
I looked in the German Citroen forum and asked a few Citroen dealers in Germany, but no success.
I hope that this set has been produced more than once and that someone has incorporated it into Xantia.
Thanks in advance.
cheers
as with MS-700.
Thanks in advance.
cheers
when it comes to fighting the excesses of
capitalism, nothing beats reverse-engineering.
- x 3283
Give citroenxm a PM (he is a member on this forum). He has managed to get Cruise Control working on a Xantia HDI (although he had the advantage that the ECU already had the relevant coding in the ECU software, so all he had to do was to connect up the right hardware for it to work).
